Average Water Temps
Old May 31, 2005 | 11:26 AM
VTECisSeXY's Avatar
*insert here*
Default Average Water Temps
Whats considered max temp and whats considered "normal"
Also, when does your fan kick on?
Old May 31, 2005 | 12:40 PM
DAguyLS's Avatar
Fan should kick on when it reaches around the half way mark.
and my hondas/acuras have always sat around 1/4 temp.
not sure exactly of the temperatures if thats what your looking for.
what seems to be your problem? overheating?
Old May 31, 2005 | 12:45 PM
Finger Lickin' good's Avatar
Default Re: Average Water Temps (VTECisSeXY)
left of the little temp picture, dont like it there. I like it between 1/4 1/3
Old May 31, 2005 | 01:27 PM
IN VTEC's Avatar
The temperature is probably right around 200 deg F, but I've seen some at around 220 deg F. It depends on what radiator and thermostat you're running, and how much water-to-antifreeze ratio you're running. Any sort of a water wetter or dish washer detergent agent can also lower the operating temps.
With a Fluidyne, 60 water/40 antifreeze mix, and a half bottle of Redline Water Wetter, my coolant temps are around 175 to 185 deg F depending on the ambient temps...as long as I don't let it idle for-*******-ever.
I think the fan thermoswitch closes the circuit at 200 deg F.
Forgot to mention that all of the temperature readings on my engine were taken through the Hondata Hondalogger.
Old May 31, 2005 | 05:32 PM
VTECisSeXY's Avatar
*insert here*
Default Re: Average Water Temps (IN VTEC)
no problem at all
Just makin sure my temps are correct. thanks!
Rein4st
Apr 7, 2012 11:17 AM
brokenojoke
14
Jan 14, 2008 07:37 PM
christiian
18
Jul 16, 2006 12:03 AM
pentaq
Sep 13, 2005 03:19 PM
Albino Dragon
Apr 18, 2002 10:15 PM
