no spark on my h22a1 obd1 engine obd2 harness with external coil???
Old May 31, 2005 | 09:33 AM
SLVRSTN_DC4's Avatar
Default no spark on my h22a1 obd1 engine obd2 harness with external coil???
I recently swapped on h22a1 in my 96 civic. I am running a p28 ecu and have an external coil to run. The dizzy cap has the spot to run the external coil and i got my power source from the igniter and my neg. from the single green wire coming from the dizzy. The thing is i get a single spark when i crank the car, but just not enough to crank over the engine. Anyone have a clue what is happening?? And yes I converted my wiring harness from civic to prelude, access motors in signal hill, CA did that for me.
I appreciate your help
Old May 31, 2005 | 03:41 PM
skunked's Avatar
Default Re: no spark on my h22a1 obd1 engine obd2 harness with external coil??? (HyptCvc_)
I know this is stupid...but did you double check your firing order? If you have spark that the only thing that comes to mind right away.
Old May 31, 2005 | 11:36 PM
Default Re: no spark on my h22a1 obd1 engine obd2 harness with external coil??? (skunked)
firing order is right, nothing wrong with it, but it just wont crank over.
98EJ7Y8
13
Jul 23, 2012 02:23 PM
daymkimchee
Jun 24, 2009 05:41 PM
spraymysol
Oct 21, 2008 05:40 PM
RaTcHeTSsss
Oct 13, 2008 09:03 AM
paulzy
Jun 24, 2002 03:52 PM
