Couple Questions concering ls/vtec with n2o
Should I cryo treat the Stock ls rods and P73-00/rings to handel the 100 shot direct port I want to do, and also will the stock sleeves be ok if I bore it out to 82mm.
I think you need to rethink your engine building strategy. First off worry about getting P73 pistons to fit an 82mm bore, then worry about gettinig it to not blow up by itself, then worry about nitrous.
