440s w/out hondata
Old Feb 7, 2002 | 03:02 PM
DragII's Avatar
25 Year Member
Default 440s w/out hondata
I'm gonna start my car up finally....I am getting hondata in about a month or so, but I went ahead and installed the 440s, and 255lph fuel pump...I don't plan on boosting till hondata is in...but my question is...
will this be ok? as in...will the car still idle, and drive alright?
Old Feb 7, 2002 | 03:38 PM
jinxproof99's Avatar
New User
Default Re: 440s w/out hondata (DragII)
you will have to run low fuel pressure. but you already know that. i wasn't that helpful after all.
Old Feb 7, 2002 | 03:40 PM
D-SPEED's Avatar
Default Re: 440s w/out hondata (jinxproof99)
wont the stock ecu go nutty with the 440s in there ? it goes into closed or open loop or something ???
[Modified by D-SPEED, 5:01 PM 2/7/2002]
Old Feb 7, 2002 | 04:28 PM
ElectronVTEC's Avatar
Default Re: 440s w/out hondata (D-SPEED)
Buy a few sets of plugs. EV.
Old Feb 7, 2002 | 04:45 PM
DragII's Avatar
25 Year Member
Default Re: 440s w/out hondata (ElectronVTEC)
gonna kill em fast eh? but it should work though right...just for temporary?
Old Feb 7, 2002 | 04:58 PM
DragII's Avatar
25 Year Member
https://honda-tech.com/zerothread?id=82211
Damn.....I'll be yanking those out this weekend
Old Feb 7, 2002 | 07:22 PM
shamoo's Avatar
Will you make something up for me please?
My buddy's LS hatch turbo with a stock ECU and 440's idles fine. He does have an S-AFC though.
Old Feb 7, 2002 | 07:26 PM
DragII's Avatar
25 Year Member
Default Re: 440s w/out hondata (shamoo)
hrm....I need a definate answer...anybody using stock ecu and 440s??
Old Feb 7, 2002 | 08:25 PM
G's Avatar
G
If you get a potentiometer, you could use the 440s. You use the potentiometer to reduce the map sensor signal. It is usually @ .80-.90 volts at 20inHg. You want @ .60-.65 volts at idle, then it will act like an AFC in reducing the map signal when you put to -40% or so. I am using 440s with a VAFC and stock obdII ecu.
Old Feb 7, 2002 | 08:29 PM
VTC_CiViC's Avatar
Default Re: 440s w/out hondata (G)
Well I can't say about a B-series, but on my D16, I use 440's with the stock ECU. I can't idle without the aid of my V-AFC though. Anything less than like -25% and it won't start. I personally idle at -45%, even at full boost (10psi) I'm still at like -12% trim.. dem 440's are big yO!
[Modified by VTC_CiViC, 12:30 AM 2/8/2002]
Old Feb 8, 2002 | 07:51 AM
DragII's Avatar
25 Year Member
Default Re: 440s w/out hondata (VTC_CiViC)
thanks for all the input...I'm yanking them till I go hondata next month
Old Feb 8, 2002 | 07:52 AM
dbman96's Avatar
New User
Yes, that would be best - you need SOME form of fuel control to run 440s.
Old Feb 8, 2002 | 08:12 AM
MackSpeed-616's Avatar
if you wanna see some fun... come over to my house and watch me swap out my hondata for my stock ecu...
Old Feb 8, 2002 | 12:26 PM
BoostedSi's Avatar
Ok, i just ordered 440cc for my '00si and should be here tomo. So i just need to adjust the fuel setting at idle only for it to run rite? Do i lower the fuel settings in the narrow and wide open throttle on the vafc at 1000 rpm? or throughout the whole rpm range, or will i not know til i dyno? btw i will be running 15psi. Sorry for all the questions.
Old Feb 8, 2002 | 12:49 PM
VTC_CiViC's Avatar
Default Re: 440s w/out hondata (BoostedSi)
15psi with no tuning other than your *** on the seat?? Kinda scarry...
Old Feb 8, 2002 | 01:19 PM
liam821's Avatar
25 Year Member
I am running DSM 450cc injectors (with a 89 CRX Si resistor box) with the help of an apex AFC in my 93 civic SI and it runs good. I currently have the fuel at -40% and it idles normal.
I am taking it to the smog place today though..i wonder if it will pass with the 450's in there? only time will tell.
liam
Old Feb 8, 2002 | 03:57 PM
2000_Civic_Si's Avatar
Default Re: 440s w/out hondata (liam821)
With 440cc injectors what is the max boost you reccomend running? I would also suggest getting hondata to contol everything.
Old Feb 8, 2002 | 04:03 PM
VTC_CiViC's Avatar
Default Re: 440s w/out hondata (2000_Civic_Si)
I belive they can fuel in the area of 350whp properly tuned
-iLLuZioN-B18C1
Oct 15, 2004 07:20 PM
superfuji57
Aug 8, 2004 07:44 PM
ZColeon
Mar 8, 2002 01:09 PM
ChiBoy
Jan 22, 2002 09:36 PM
