need help on my motor swap
Old May 29, 2005 | 10:48 AM
SPANKB18C's Avatar
Default need help on my motor swap
i did a motor swap on my 92 lude i took out a f22 and put in a h22 . everything went good . now the problem, i went to hook up the ecu and the plugs on my harnes is diff then the plug holes on the ecu for the h22 the motor is out of a 96 lude and i was told it is a obd2 and my car is a obd 1 and that might be the problem, if so what do i have to do to fix the problem. if you could help that would be great . thanks. jeff..
Old May 29, 2005 | 10:59 AM
allmotor99lude's Avatar
Default Re: need help on my motor swap (SPANKB18C)
you can buy a harness that adapts obd1 to obd2. your 96 motor is almost definetly obd2 and ur car is obd 1. the harness is like 150 think. unless you know how to splice your own ecu wires.
Old May 29, 2005 | 11:06 AM
SPANKB18C's Avatar
Default Re: need help on my motor swap (allmotor99lude)
well if i had the right plug to the ecu i could do that but where could i get a obd2 harnes no yunk yards around here a 96 up lude.
Old May 29, 2005 | 09:44 PM
Speedra500's Avatar
i believe all OBD2 harnesses are the same, with respect to shape, you should be able to get a harness off any 96+ honda and build your own harness if you are so inclined
Old May 29, 2005 | 09:48 PM
luderacer_92's Avatar
this might seem a little dumb but get a obd1 ecu form a 93-95 vtec prelude it should just plug in it may be your best bet...
Old May 30, 2005 | 05:14 AM
SPANKB18C's Avatar
good idea ill start looking for one if i can get a obd1 ecu with the vtec ill be good? what about the knock senser?
Old May 30, 2005 | 06:43 AM
enigma_00i's Avatar
Hi:
An earlier posting suggested that you purchase an OBD conversation/adaptor harness - that allows you to sync obd1 to obd2. Unless you're proficient in the field I would not recommend you try splicing. The prices varies from 90-150.
I have some additional info since I swapped a B18C1 [GSR] into an 84 Prelude chassis and is running very well.
BR
Old May 30, 2005 | 09:04 AM
SPANKB18C's Avatar
yeah ill take all the info i can get . i might have it worked out with a guy on here who has a 93 jdm p-13 ecu obd1 that he said will work. so if it will work im going that, i need to make sure i don't have a knock senser problem.
chivid
Mar 7, 2011 04:30 PM
tgreene2098
Aug 27, 2009 03:09 PM
hollywood96ex
Jan 30, 2009 01:56 PM
CivicFerioSiR
Aug 25, 2003 08:22 AM
BruceLee
Nov 11, 2001 08:25 PM
