EJ1 JDM Gauge Cluster question?
Old May 28, 2005 | 09:43 AM
JDM SLICK's Avatar
Default EJ1 JDM Gauge Cluster question?
what's up guys? I just recently traded my eg6 gauge cluster for an ej1 cluster just like the one pictured below.
Modified by JDM *** at 7:14 AM 5/30/2005
Old May 28, 2005 | 09:54 AM
JDM SLICK's Avatar
anyone?
Old May 28, 2005 | 09:57 AM
_BEN_'s Avatar
Default Re: (JDM ***)
Never seen one of those before.
Probably almost as rare as one of these.
Old May 28, 2005 | 09:59 AM
e jay one's Avatar
Default Re: (_BEN_)
https://honda-tech.com/zero...age=1
you might wanna try to get a hold of this guy he has the exact same cluster and one clean *** ej1.
Old May 28, 2005 | 10:24 AM
e2000's Avatar
where is that cluster from _ben_?
Old May 28, 2005 | 10:54 AM
_BEN_'s Avatar
Default Re: (e2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e2000 &raquo;</TD></TR><TR><TD CLASS="quote">where is that cluster from _ben_?</TD></TR></TABLE>
Thats a ukdm cluster. They pop up on ebay every now and then and usually go for about $300 unless you are lucky and can get it for less.
The ef ukdm cluster are a little easier to find and they also go up to 140mph.
There are a few EF clusters on ebay now. And one EP cluster that goes to 160mph.
Old May 28, 2005 | 10:57 AM
neutron91's Avatar
Default Re: EJ1 JDM Gauge Cluster question? (JDM ***)
it should work with no modification... try checking the bulb to see if its burned out... when i got mine it had numerous bulbs that were burned out... replaced them all and it works great
Old May 28, 2005 | 11:01 AM
JDM SLICK's Avatar
Default Re: EJ1 JDM Gauge Cluster question? (neutron91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neutron91 &raquo;</TD></TR><TR><TD CLASS="quote">it should work with no modification... try checking the bulb to see if its burned out... when i got mine it had numerous bulbs that were burned out... replaced them all and it works great </TD></TR></TABLE>
so that means taking out the tach from the cluster right? cuz I took my cluster out today to examine if the bulbs for the "coupe" were behind the cluster...i didn't see any bulbs behind it...so i figured they're inside the cluster behind the tach no?
Old May 28, 2005 | 11:18 AM
TallAssFilipino's Avatar
That gauge cluster wasn't just available for the 2dr's. They were just available for both the 2dr's and hatches equipped with TCS. I've come across a couple TCS-equipped Civic hatches with that gauge cluster in UK and Japan.
Our USDM Civic hatchback doors don't have the door sensors on them that allow the TCS gauge clusters to work. So, the side door indicators won't work. On my first Si hatch, I had to buy another passenger-side door and got a JDM door. It had the sensor (switch-thing) in it by the door-latch that my USDM door didn't have. Wires would have to be ran to get it working. It doesn't use your existing door/domelight circuit. As far as your trunk circuit, you may need to repin it on the harness plug. I never got as far as the trunk circuit. I ended up selling that Si.
Old May 28, 2005 | 11:41 AM
JDM SLICK's Avatar
Default Re: EJ1 JDM Gauge Cluster question? (MDJ IKNJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MDJ IKNJ &raquo;</TD></TR><TR><TD CLASS="quote">That gauge cluster wasn't just available for the 2dr's. They were just available for both the 2dr's and hatches equipped with TCS. I've come across a couple TCS-equipped Civic hatches with that gauge cluster in UK and Japan.
Our USDM Civic hatchback doors don't have the door sensors on them that allow the TCS gauge clusters to work. So, the side door indicators won't work. On my first Si hatch, I had to buy another passenger-side door and got a JDM door. It had the sensor (switch-thing) in it by the door-latch that my USDM door didn't have. Wires would have to be ran to get it working. It doesn't use your existing door/domelight circuit. As far as your trunk circuit, you may need to repin it on the harness plug. I never got as far as the trunk circuit. I ended up selling that Si.</TD></TR></TABLE>
Gotcha
Modified by JDM *** at 8:34 PM 5/31/2005
Old May 28, 2005 | 12:27 PM
BlueIntegraBoy's Avatar
Yeah, that's an EG6 cluster with the optional TCS and door open indicator.
teg_dc2
Aug 25, 2008 07:32 PM
jedubz
Aug 29, 2005 05:37 PM
91sicrxer
19
Mar 11, 2005 03:00 PM
ng
Dec 27, 2003 05:49 PM
SuPeR_MaN
10
Aug 7, 2002 07:18 AM
