Dodgy skunk2 cams??
Old May 28, 2005 | 05:07 AM
jrubenis's Avatar
Default Dodgy skunk2 cams??
Fitted some stage 1 sk2 cams to my b16 del sol. Idle is terrible and when vtec engages my car loses power. I have checked everthing i can think of which includes-Cam timing, ignition timing, valve clearances, fuel pressure, compression tested, vacuum leaks etc. Everthing checks out ok, can anyone help???? I got an ingen long race filter.4 branch manifold, AEM fuel rail and pressure valve. thanks. james UK
Old May 28, 2005 | 09:51 AM
hatch34's Avatar
Default Re: Dodgy skunk2 cams?? (jrubenis)
tune it
Old Jun 1, 2005 | 09:04 AM
jrubenis's Avatar
Default Re: Dodgy skunk2 cams?? (hatch34)
Thats the first thing i tried mate. my local tuner is as confused as i am. Any one with similar problems or ideas please help. james uk.
Old Jun 1, 2005 | 01:01 PM
per4mance's Avatar
sounds like your riming is off check your crank timing ,and you cam timing again.
Zer0skll
Nov 14, 2007 09:17 AM
jrubenis
May 9, 2005 09:55 PM
typesguy
Dec 6, 2004 12:22 PM
durrett syndrome
Sep 7, 2003 07:56 AM
