Help! Engine Noise (LS/VTEC)... video included
Old May 28, 2005 | 04:50 AM
93preludes's Avatar
Default Help! Engine Noise (LS/VTEC)... video included
Hey guys,
I dont post much since search usually solves everything... but I am trying to help a coworker out with his ls/vtec he recently had built and I'd apprecate your help on this one.
This thing was built by someone from this board, they were paid alot of money and now they've disappeared and the car is screwed. We're trying to get this thing running since right now the car is pretty much undriveable and it also sounds pretty bad...
I have included a vid I made with my phone and I know the audio isnt the greatest but if you turn the sound down it's more noticeable... there is a screeching and loud clattering sound that it's making, almost like it's running dry. We made sure that there's enough oil and coolant in there...
I'm planning to do a compression test, pull the valve cover and drop the oil pan and look around for any shavings, i've searched and found that there have been other people with similar problems and it ended up being a spun rod bearing(crap!)...
I just want another opinion on this before I move ahead... any additional suggestions would be great. the last thing this thing had done was a timing belt and an ecu swap. The screeching sound is new, previously it just sounded almost like there was a loose shaft in the motor, like loud clapping...
motor specs: B16 head, ITR pistons/? Rods... i'll try and get more details up soon.
vid: LSVTECNoise.avi
turn the sound down a bit and right click save as please...
Old May 29, 2005 | 08:24 PM
93preludes's Avatar
Default Re: Help! Engine Noise (LS/VTEC)... video included (93preludes)
anyone? ttt
Old May 29, 2005 | 10:09 PM
b16a27's Avatar
im not no pro but it does sound like a rod bering but more then one my friend has a dsm and he spun all 4 main bering not exactly the same sound but its pretty close
Old May 30, 2005 | 10:52 AM
93preludes's Avatar
Default Re: Help! Engine Noise (b16a27)
damn, all 4? not that it makes much of a difference in the long run, if it's 1 or 4 the fix is the same...
How many people actually get this type of a problem 'repaired'? I figure if it's got a spun bearing then the solution is just going to be to find a shortblock for it... is there a cheaper alternative? thanks in advance..
Old May 30, 2005 | 11:48 AM
WestCoRacer's Avatar
Since it is an ls/vtec, maybe the wrong head gasket was used and you are getting no oil to the top of the cylinder head and rockers, etc. I've messed with Hondas for years and never heard a noise like that. Check under the valve cover for oil or lack of oil.
Old May 30, 2005 | 06:36 PM
b20izzle's Avatar
who built ur motor? i had the same sound and thought it was my valves. ending up being my piston skirt banging against teh cylinder walls.
Old May 30, 2005 | 06:59 PM
JSPECEX's Avatar
Default Re: Help! Engine Noise (b20izzle)
i wouldn't start that anymore it sounds like either valve contact or that it has a really really bad injector miss but i doubt it i would go with vlvetrain noise or piston to valve contact **** sound though so i am not sure
Old May 30, 2005 | 07:33 PM
torr's Avatar
Default Re: Help! Engine Noise (JSPECEX)
hard to tell:
may be valvetrain, maybe not.
if it is a rod= let the car run and pull one spark plug wire at a time to see if the noise goes away. if the noise goes away than possibly a rod bearing on that cylinder.
did you flood the motor by chance? if so than you could've washed the cylinders=pistons toasted.
only way to know for sure is to dissassemble it.
Old May 31, 2005 | 03:17 AM
1993sir05's Avatar
Default Re: Help! Engine Noise (torr)
what the hell do you mean by this. enlighten me.
Old May 31, 2005 | 07:50 AM
b20izzle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by torr &raquo;</TD></TR><TR><TD CLASS="quote">hard to tell:
only way to know for sure is to dissassemble it.</TD></TR></TABLE>
thats how i knew my pistons were toast..had to dissassemble.
Old Jun 5, 2005 | 02:43 PM
93preludes's Avatar
We were finally able to get the car to my garage, I'm going to drop the oil pan and pulling the valve cover so I can find out what's going on with this thing... i'll have pictures up tomorrow morning.
The block had an ITR oil pump put in it... could this cause any kind of a problem? I've heard of people using this pump without any problems... anyone have any issues with it?
Thanks for the replies so far!
Modified by 93preludes at 8:00 PM 6/6/2005
Old Jun 5, 2005 | 05:24 PM
evilhatch2.0's Avatar
Default Re: Help! Engine Noise (93preludes)
check your header bolts at your cylinder head, and timing.
good luck
Old Jun 5, 2005 | 05:38 PM
93preludes's Avatar
Default Re: Help! Engine Noise (evilhatch2.0)
I think we found the problem... pretty interesting/scary. Here's a pic of what we found when we pulled the valve cover.
This the exhaust side... the nuts somehow came off? I dont know how it could happen but I guess if they were loose enough... One of the nuts we found in the head but the other we could not find... we suspect this is the problem, how bad could this be?
what's the worse case scenario in this situation? could the nut somehow fallen in an oil passage and caused damage? otherwise, would this be the cause of the tapping? valves tapping against the piston? any advice is appreciated.
thanks in advance
Modified by 93preludes at 8:07 PM 6/5/2005
Old Jun 5, 2005 | 07:31 PM
hayabusa160's Avatar
damn....thats nuts. drop you pan and see if its down there...
Old Jun 6, 2005 | 05:24 PM
93preludes's Avatar
Default Re: Help! Engine Noise (hayabusa160)
Could not find the nut in the oil pan but I did find some shavings... but just from looking at the block there doesnt appear to be an obvious spun a bearing? I've seen spun rod bearings before and they're usually pretty obvious... but I cant recognize any obvious damage...
could these shavings have come from somewhere else? the head? I'm a little baffled since the block/rods dont look torn up. any help would be appreciated...
Old Jun 6, 2005 | 06:10 PM
tmac007's Avatar
That nut had to go sumwhere.... I personally wouldn't just leave it floating around. check all your oil galleries and make sure its not stuck in one of them. If its not. i dont know what to tell you. good luck man
phil2000's Avatar
from what i can tell from the pic, those are destroyed bearings mike, sorry to tell ya. That looks like what I found in the oil pan of my old H23-vtec.
Old Jun 6, 2005 | 06:53 PM
93preludes's Avatar
Default Re: (phil2000)
suck! i remember what yours looked like... I guess it's confirmed, bearings... I'm going to see what this guy wants to do then decide if its going to get rebuilt or just swapped for another motor...
the motor was built by "This one" not too long ago, but he's nowhere to be found now...
hopefully this will help someone else with a similar problem.
thanks for the replies!
Old Jun 9, 2005 | 01:41 AM
RATED EG's Avatar
Default Re: (93preludes)
that sounded liek my motor before i blew it at the track but it wasnt that bad sounding like that....it only made that noise when i reved it a little bit -___-
Old Jun 9, 2005 | 11:57 AM
blacksihatch's Avatar
these pics dont look good you may need to tear the motor apart ( that sucks)replace the bearings, turn the crank, all that good **** and of course when the entire motors apart it will be interesting to find out where you find the nut..
Old Jun 11, 2005 | 04:12 PM
93preludes's Avatar
Default Re: Help! Engine Noise (blacksihatch)
Just to update, it was the number 4 rod that spun the bearing... scored the crank, we're going to be working towards rebuilding in the coming weeks. Thanks for the help...
sohctodohc
Jan 27, 2008 10:58 AM
myke5505
Mar 15, 2005 12:03 PM
honeymayamaya
Jun 15, 2004 07:49 AM
t-blizzard
15
Dec 17, 2003 05:14 PM
Kristo92
Sep 19, 2003 08:27 AM
