Jagged holes in my HEAD WTF! Vtec intermittently works?
Old May 27, 2005 | 07:19 PM
Demented's Avatar
Default Jagged holes in my HEAD WTF! Vtec intermittently works?
Heres my setup first:
Fully built/sleeved/bored Ls block
95 gsr head
chipped p28 vtec solenoid w/no oil pressure sensor
motor has 10k
First vtec works intermittently, checked voltage to solenoid with a meter while driving, has voltage but no kick. Sometimes vtec does hit its 50/50.
yes it has oil, engine is at operating temp.
Also on a cold start there is a ticking noise from the head, its not my rod slap. Ticking goes away after 5 minutes.
So I clean my vtec solenoid screen and theres metal shavings! hmmm I open up the valve cover and see these jagged holes inside the head on each side
Any thoughts on these holes doesnt look factory?
Also about the vtec, could my LMA's be going out?
Sorry for the long post.
Thanks
Old May 27, 2005 | 07:30 PM
machine4321's Avatar
its just rough casting around the oil return holes ..not a big deal as most honda heads have these //the oil returning to the crank isnt really under pressure so flow isnt a big concern here
as far as no vtec..are you getting codes at all
do the metal shavings come back after its clead out ..if so theres a problem
Old May 27, 2005 | 07:38 PM
Demented's Avatar
Default Re: (machine4321)
no CEL's
I'm kind of ruling out the ecu, Something happens at the vtec engagement point all the time, sometimes it pulls, and sometimes it doesnt pull
I searched on bad lost motion assemblies
Old May 27, 2005 | 09:42 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: Jagged holes in my HEAD WTF! Vtec intermittently works? (Demented)
sounds like you may have damaged your rod, or main bearings, what color are the shavings?
Old May 28, 2005 | 12:59 AM
Demented's Avatar
Default Re: Jagged holes in my HEAD WTF! Vtec intermittently works? (PURPLETERROR)
silver shavings, but what does the holes and the vtec have to do with my rods and bearings?
Old May 28, 2005 | 04:16 AM
NJIN BUILDR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demented &raquo;</TD></TR><TR><TD CLASS="quote">silver shavings, but what does the holes and the vtec have to do with my rods and bearings?</TD></TR></TABLE>
Its about where the shavings came from,not the casting flash on the drain holes.
Glenn
Old May 28, 2005 | 07:32 AM
Demented's Avatar
Default Re: Jagged holes in my HEAD WTF! Vtec intermittently works? (NJIN BUILDR)
so are those holes normal?
Old May 28, 2005 | 07:57 AM
mmuller's Avatar
Mad Scientist
yes
Old May 28, 2005 | 08:18 AM
Garcia-Racing's Avatar
Drop the pan and look for damage in the bottom end. If a rod or main bearing is going, oil pressure will drop and vtec wont engage.
Old May 28, 2005 | 08:47 AM
TrackSpeedRacing's Avatar
those holes are perfectly normal.
Old May 28, 2005 | 10:07 AM
.water's Avatar
Default Re: Jagged holes in my HEAD WTF! Vtec intermittently works? (1320JDMGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1320JDMGSR &raquo;</TD></TR><TR><TD CLASS="quote">those holes are perfectly normal. </TD></TR></TABLE>
wow..really? to me seems like fuked..lol
Old May 28, 2005 | 08:55 PM
Demented's Avatar
Default Re: Jagged holes in my HEAD WTF! Vtec intermittently works? (Chris DC2)
haha thanks
Old May 29, 2005 | 08:15 AM
Demented's Avatar
I dont have a vtec oil pressure switch, so even though my pressure was low, vtec would still work.
Old May 29, 2005 | 09:36 AM
k2490si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demented &raquo;</TD></TR><TR><TD CLASS="quote">I dont have a vtec oil pressure switch, so even though my pressure was low, vtec would still work.</TD></TR></TABLE>
it takes oil pressure to lock in the vtec rockers. so if you do not have enough oil pressure in the head and the solenoid kicks open, vtec may not work.
hook up an oil pressure gauge
Old May 29, 2005 | 10:09 PM
hybridpatient95's Avatar
what should oil pressure be at before vtec? and in vtec?
Old May 29, 2005 | 11:08 PM
k00lt1nt's Avatar
Default Re: (frankenfiend 04)
should be atleast at 60 psi to engage
BCSi00
Sep 24, 2020 12:09 AM
4.8t
Aug 2, 2011 08:36 PM
acc97lxAndy
Aug 19, 2003 12:30 PM
Casper1379
May 17, 2001 10:57 AM
