When to Replace Clutch?
I tried a search and didn't find to much info about when to replace the stock clutch.
My 2000 R has about 55k on it and has never been to the track...its daily driven and my clutch is starting to make a sloopy squooshy noise when engaged? I'm not a Tech so I'm not sure what needs to be replaced or what brand to go with. I'm happy with the stock feel. Can anyone helpout a Clueless R owner
i had a similar problem with my accord. i was leaking fluid at the slave cylinder. i replaced the slave and all problems are gone, welll i also had a slipping clutch too.
so anyway, with only 55k i doubt you have a bad clutch. check the slave cylinder and see if there is a fluid leak. you might also need to flush your MC?
i just noticed that the noise and feel of the clutch gets sloopy after driving for 30min or so where should i take the car to have someone look at it....
From: With my POS D15B2, Whereever whenever, United States
a clutch is not that hard to do, its a piece of cake.
Hey D, if you know how to adjust valves and rebuild heads, let me know, I am in dire need of a valve adjustment
