When to Replace Clutch?
Old May 27, 2005 | 01:55 PM
Trellis's Avatar
Default When to Replace Clutch?
I tried a search and didn't find to much info about when to replace the stock clutch.
My 2000 R has about 55k on it and has never been to the track...its daily driven and my clutch is starting to make a sloopy squooshy noise when engaged? I'm not a Tech so I'm not sure what needs to be replaced or what brand to go with. I'm happy with the stock feel. Can anyone helpout a Clueless R owner
Old May 27, 2005 | 02:39 PM
SecretAgent's Avatar
sounds like you might have a hydraulic problem. the slave or master cylinder may be going out.
Old May 27, 2005 | 03:45 PM
Art Vandeleigh's Avatar
Default Re: When to Replace Clutch? (Trellis)
i had a similar problem with my accord. i was leaking fluid at the slave cylinder. i replaced the slave and all problems are gone, welll i also had a slipping clutch too.
so anyway, with only 55k i doubt you have a bad clutch. check the slave cylinder and see if there is a fluid leak. you might also need to flush your MC?
Old May 31, 2005 | 05:19 AM
Trellis's Avatar
Default Re: When to Replace Clutch? (Art Vandeleigh)
i just noticed that the noise and feel of the clutch gets sloopy after driving for 30min or so where should i take the car to have someone look at it....
Old May 31, 2005 | 07:44 AM
D's Avatar
D
i'm in the philly area, and jobless. pm me if you are somewhere nearby.
Old May 31, 2005 | 08:55 AM
Trellis's Avatar
Default Re: When to Replace Clutch? (D)
thanks for looking out....I have an appointment with Dan GSR to take a look ...he about an 1hour from me.
Old May 31, 2005 | 09:02 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
a clutch is not that hard to do, its a piece of cake.
Hey D, if you know how to adjust valves and rebuild heads, let me know, I am in dire need of a valve adjustment
Old May 31, 2005 | 09:33 AM
itr1244's Avatar
Default Re: When to Replace Clutch? (MugenHonda)
just replace it when it starts to slip..
but i'm replacing mine soon even tho it still got alot of meat left..
my car has 97000km.
Technot
Mar 18, 2018 12:55 AM
hannslebo
Mar 24, 2009 01:53 PM
K-Spec
Sep 26, 2006 11:30 PM
RiCE On IcE 2
Jun 22, 2005 07:10 PM
vincent97gsr
Oct 10, 2002 03:41 PM
