Clutch problem??
Old Oct 10, 2002 | 09:29 AM
vincent97gsr's Avatar
Default Clutch problem??
My clutch has 73000 on it and now it is starting to feel soft. Also when you push it in the first of the push is very easy requiring no effort. This was not like this when I bought it with 48000. Is there any way to solve this other than replacing my clutch? Maybe bleed a hose or something?? I have no idea.
Old Oct 10, 2002 | 10:16 AM
ALF's Avatar
ALF
Default Re: Clutch problem?? (vincent97gsr)
Either one of your clutch cylinders are on their way out or you simply need to bleed your clutch.
Check to see if you have any fluid leaking to the firewall below your clutch master cylinder. If you see fluid or traces of it, it will die soon and will need replacement. Usually when you have to replace one cylinder, it's best to replace both.
I would clean the area around the clutch master cylinder and bleed the clutch. If you see fluid after a day or so, the clutch master cylinder is the culprit and will need replacement.
Old Oct 10, 2002 | 03:41 PM
Default Re: Clutch problem?? (ALF)
Thanks alf I guess I owe you a cat
hannslebo
Mar 24, 2009 01:53 PM
Lb1atx
Sep 7, 2007 05:16 AM
Greenery18
Jul 8, 2005 04:22 PM
DriveSideWays
Aug 27, 2004 05:06 PM
myhatchrips
Dec 5, 2003 07:21 AM
