Gm map sensor wiring??? Already searched..
My wires coming off the map sensor are white/blue, blue/white, and red/white and i don't have access to a multi-meter. So which wire goes to A,B,and C??
I have a 94 h22.
Modified by x-1 at 2:44 PM 5/27/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PK SPEED »</TD></TR><TR><TD CLASS="quote">GND=A green/white
MAP signal=B white
5VOLT=C yellow/green</TD></TR></TABLE>
just confirming.
MAP signal=B white
just confirming.
MAP signal=B white
Please read my first post again and you will notice that my colors are not the ones that you just specified.
MAP signal=B white
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin »</TD></TR><TR><TD CLASS="quote">http://hondata.com/tech3barmap.html</TD></TR></TABLE>
It does not have the wiring for a 94 h22.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">For verification check inside the Honda Map sensor plug. The pins may be labeled with V O G - for Voltage, signal and ground.</TD></TR></TABLE>
Worst case scenario, get a multimeter. They are very useful.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x-1 »</TD></TR><TR><TD CLASS="quote">Nobody got a 3 bar map sensor in a 94 h22?</TD></TR></TABLE>
The colors shouldnt matter, it should be like A B C for the hook up. Just get multi-meter and probe the connector and match em up. Does your 3bar have A B C on the plug or no ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PK SPEED »</TD></TR><TR><TD CLASS="quote">The colors shouldnt matter, it should be like A B C for the hook up. Just get multi-meter and probe the connector and match em up. Does your 3bar have A B C on the plug or no ?</TD></TR></TABLE>
Yes it does.
Yes it does.
I hope you get that wiring sorted out. By the way guys, is the MSD 3 bar map is the same as the GM 3 bar map? sound kind of silly but X1 has one of this MSD 3 bar brand. Does it matter as long as it's 3 bar? thanks.
should be same hook up since a 3wire plug, sure the 3wires go to same port. But might wanna contact MSD to confirm this if not sure. I say hook it up and see .
