The CEL that just won't go away.
Old May 27, 2005 | 11:29 AM
Nytmair's Avatar
Default The CEL that just won't go away.
So i have a CEL, did the little paperclip trick, #41, o2 sensor, which is what the previous owner told me it was. Ok, i got a used through a HT member and put it in while it was at the shop getting painted, so it was started a handful of times. I figured that would be enough ignition cycles to reset the CEL. I finally got the car home and today I tried to reset the ECU to clear the code but it won't go away.
1) Do i need to drive it (a.k.a. not just let it idle) for it to complete an ignition cycle?
or
2) Do did i just buy another bad o2 sensor?
or
3) Is there any other answers you people may have?
Thanks for any help. i'd appreciate it
Old May 27, 2005 | 11:39 AM
IHateJDM's Avatar
Default Re: The CEL that just won't go away. (Nytmair)
could be bad o2, could be bad wiring
Old May 27, 2005 | 11:42 AM
hndagirl's Avatar
Default Re: The CEL that just won't go away. (IHateJDM)
after u reset it did u take off the positive and negatives off the battery for 20 seconds?
that will reset the ecu.
SoSlo's Avatar
disconect the battery for about 10 min then hook it up and start the car. if the cell did not go away you may have a bad o2 you should check the wiring prior to getting another 02
Old May 27, 2005 | 11:44 AM
hndagirl's Avatar
Default Re: The CEL that just won't go away. (SoSlo)
10 mins is a little long..20 seconds is good enough
Old May 27, 2005 | 11:46 AM
Nytmair's Avatar
yeah i did all that and i still have the CEL...
which wiring would I check exactly?
Old May 27, 2005 | 11:54 AM
alleyezonme's Avatar
Default Re: (Nytmair)
do you have 2 o2's??
Old May 27, 2005 | 11:56 AM
IHateJDM's Avatar
Default Re: The CEL that just won't go away. (Ms. Happyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ms. Happyman &raquo;</TD></TR><TR><TD CLASS="quote">10 mins is a little long..20 seconds is good enough</TD></TR></TABLE>
just turn on your headlights after disconnecting the positive. it'll drain all residual power, so no waiting .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nytmair &raquo;</TD></TR><TR><TD CLASS="quote">yeah i did all that and i still have the CEL...
which wiring would I check exactly?</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1171263
Find the pinouts the heater wires lead to, and trace them to the o2.
John3
Nov 13, 2017 11:43 AM
black38
Sep 5, 2012 09:35 AM
Milano97
Apr 5, 2004 11:48 AM
EVOCELICA
Nov 20, 2002 11:44 AM
