Headlight Problem
Old May 27, 2005 | 12:22 AM
96Civic_Coupe's Avatar
Default Headlight Problem
i've been having issues with my drivers side headlight for months now.
before i did the 99 conversion on my car, the drivers side headlight was always brighter than the other.
one day i rear ended someone and decided to do the conversion, i changed all the bulbs and im still having the same problem. except now the the drivers side turn signal doesnt turn on. it only turn on when i make a turn. but it blinks really dim and really fast. (the driver side rear also blinks fast but not dim)
help me out guys, is this a wiring issue, a fuse issue, what?
Old May 27, 2005 | 01:15 AM
_Cyclone_'s Avatar
Default Re: Headlight Problem (96Civic_Coupe)
Yeah it sounds like you have a short somewhere in that harness for the headlight. Do you have any blown fuses or blow any certain fuse regularly?
Old May 27, 2005 | 04:28 AM
96 SOHC VTEC's Avatar
Default Re: Headlight Problem (CycloneBlue_1.6EL)
Sounds like you are having ground issues to me. Check all your connections to and from the lights.
Old May 27, 2005 | 05:51 AM
_Cyclone_'s Avatar
Default Re: Headlight Problem (96 SOHC VTEC)
Yeah, could be that too.
Old May 27, 2005 | 03:18 PM
how many ground connection are there?
Old May 27, 2005 | 06:26 PM
bump, i need some help
Old May 27, 2005 | 07:25 PM
_Cyclone_'s Avatar
Default Re: (96Civic_Coupe)
All ground connections from that light go to ground connection G202. If the problem is actually a ground, it would have to be in the individual wire for the light that isn't working. How well does the windshield washer pump work? Does anything change with the lights when you spray it? (Washer pump is on G202 as well.)
Old May 27, 2005 | 07:28 PM
_Cyclone_'s Avatar
Default Re: (CycloneBlue_1.6EL)
When you're done looking at it, if it's not a ground problem (which it prolly won't be...) look at the harness for the turn signal bulb. Inspect it carefully to make sure there is no obvious damage, shorting, etc. Look at as much of it as you can. If you don't see anything, I'll tell you how to do some tests on it with a multimeter or a test light. If you don't have either of those tools, I suggest you go out and get a test light at the very least.
Old May 27, 2005 | 07:40 PM
wheres the G202 connection?
also, what do u mean by shorting on the light bulb harness?
Old May 27, 2005 | 07:42 PM
_Cyclone_'s Avatar
I believe G202 is under the fender behind the headlight... it is on my car anyways. Look for something obvious, like a place where the wiresheeting is missing or burned or something like that.
Old May 28, 2005 | 12:08 AM
somone told me to get a new bulb harness. they also told me to make sure i splice them right. what the hell is splice? and do i need any tools?
Old May 28, 2005 | 09:38 AM
_Cyclone_'s Avatar
Before getting anything new, I suggest you test the one you have. Did you inspect the harness yet?
Tvg9
Lighting
May 28, 2014 09:25 AM
jtthwaits
Mar 5, 2011 05:40 PM
ultima.maniac
May 18, 2008 05:06 AM
Uncle Ben's
Jul 8, 2007 12:08 PM
