bogging @ 10% throttle
i have the same problem on my b16 crx, im crusing at about 10% throttle and i get boggin and sputer ,but as soon you give it gas I dont have that problem.
Im wondering the same thing
The 2 most likely possibilities are either the O2 sensor or the TPS...
if its the TPS, its possible you have to rewire it... There are 3 wires that lead to the plug, one is ground, which you leave alone, and you have to swap the other 2...
one has a constant (i think) 4.5v and the other is a fluctuating voltage depending on throttle possition.. I had the 10% stutter, rewired the tps, and gone.. after a year+ of having it and trying everything in the world...
hope this helps
hope this helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kingteghelm »</TD></TR><TR><TD CLASS="quote">Did u watch somebody adjust the tps or did someone else do it again</TD></TR></TABLE>
yeah rob the guy who helped do the swap had adjusted it but nothing changed im not sure at all what it would be. i heard some guy had the same problem like this and after driving it for so long it just went away but i want to try and fix it before something goes wrong....im SICK of **** going wrong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thatbluecrx »</TD></TR><TR><TD CLASS="quote">I seriously think you should look into what I wrote above... at worst you have a respliced wire if it didnt fix it
alright then i will look into rewiring and hopefully solving the problem thanks
</TD></TR></TABLE>alright then i will look into rewiring and hopefully solving the problem thanks
haha, this recently started on my car, I said to myself maybe the o2 sensor. The next day I go get a resonator and bang, the wire of the o2 sensor was just there hanging. Gonna go to the junk yard this weekend cause I cant grasp the wire from the sensor no more.
