throttle position sensor
Old May 1, 2002 | 04:56 AM
accord_ex90's Avatar
Default throttle position sensor
there are three wires on the throttle position sensor, which of these three wires control the wide open throttle response?
Old May 1, 2002 | 05:23 AM
SOHCArchangel's Avatar
Default Re: throttle position sensor (accord_ex90)
dude, your question makes no sense, the TPS is just that its a sensor response is directly accociated tot he throttle cable which is attatched to the gas pedal, which yu0 push. IF you are inquiring about engine responsiveness there is a whole system of variables that comes into play, not 'which wire off the tps sensor'.
Old May 1, 2002 | 05:36 AM
Default Re: throttle position sensor (SOHCArchangel)
man, i'm not talking about the throttle cable connected to the gas pedal. it's the plug that sits behind the throttle body. there are three wires that conects to that plug. one is suppose to change voltage when the throttle is wide open. i just don't know which one it is.
Old May 1, 2002 | 05:38 AM
well that more clearly explains what you are looking for other than "throttle response"
you might want to check a helms manual on this one as i dont rember off the top of my head, hopefully someone else can give insight.
Old May 1, 2002 | 08:31 AM
Accord94DX's Avatar
white wire. check the helms though, I installed the n20 kit @ midnight a long time ago so the details are a lil sketchy.
Old May 1, 2002 | 10:36 AM
Stew Pidasso's Avatar
It is the white one.I believe it's also in the middle.
Old May 2, 2002 | 08:17 AM
Default Re: throttle position sensor (Nitz5785)
thanks, it's for my zex kit by the way...
Jimmydwrench
Sep 2, 2018 04:36 PM
stranskydw
Jul 12, 2008 12:40 PM
oz`Vtec
Feb 18, 2005 03:51 AM
GSRcivicGSR
Dec 20, 2004 04:29 AM
GsRwHiTe
Mar 22, 2004 03:08 PM
