TPS sensor
TPS sensor
I put on a 'new" TPS sensor on my swap, but now unfortunately the car will not drive. I take it outta 1st hit the gas and nothing happens? The revv's don't climb. I checked if it was the throttle cable but it is opening up the plate, so I assume it is the tps which I haven't calibrated.
What's the easiest way to calibrate it? I tried getting my multi-meter leads into the wires but it seems impossible.. I also tried using some longer pins but they wouldnt stay in.
also .4V is 0%throttle and 4.5V is WOT? correct?
Re: TPS sensor (ek_chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_chris »</TD></TR><TR><TD CLASS="quote">I put on a 'new" TPS sensor on my swap</TD></TR></TABLE>
are you telling me that nowdays, cars have throttle position sensors with sensors on them!!??1 cars are becoming way too advanced
sorry, were you tryin to ask a question?
If it was off that bad it would throw a CEL. I've drove with a TPS sensor unplugged, on OBD 1 it shouldn't make a difference but you could have other problems that could make the car unable to rev.
Re: (nsxmatt)
yeah the TPS just acts as an accelerator pump so when you jab the throttle the ecu can quickly compensate with fuel. In theory you can drive a car with the TPS unplugged, and if you accelerate slowly, you shouldn't notice much of a difference. But to us honda heads, the TPS is our best friend.
And yeah it would throw a cel. So it sounds like you have other issues going on.
it is throwing a cel
6 and 7. I replaced the coolant temp sensor, so all thats left is the tps. But the tps should be in working order.. it just isnt calibrated
b20 with p06 ecu with a p75 map slightly scaled for a 2.0 (i got the p8r head not the p75 head). Ya I'm going to unplug it reset the ecu and let it idle for 10 minutes then see if she drives.
Re: (ek_chris)
Try de-pinning it and switching some wires around, that's what I did on my B16 and voila! it worked.
Do search in the archives under "TPS" and you should get and answer.
deucedeuceEK
04-27-2007 02:39 PM
