Brake System Inspection - Pad Questions...
The mushy brake pedal has prompted me to do a full brake inspection, thinking that the soft pedal may be more than needing to bleed the brakes (again).
My rear pads are toast (time to call Andie). I know lots of people are running the Cobalt Spec-GT in the rear with the Spec VR up front so I thought I would give those a try (had the Endless CCX).
I did noticed some weirdness in the front pads.
1) One of the pads from each front corner is worn more than the other from the same corner (I don't know if it is the inside or outside pad). Is this normal? Should I 'rotate' them? Which side normally wears faster?
2) I noticed some breaking apart of one of the pads near the top edge. Is this anything to worry about? Here is a pic of what I am talking about:
Thanks for your help guys.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">That wear is normal and yes you can rotate it. </TD></TR></TABLE>
Do you know which side normally wears faster? I don't want to accidently jsut put them in the same way they were...
the inside pad always wear faster...
part of that is bc most people do not remove the dust shield
the uneven pad wear can be taken care of by purchasing some sp00mage
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux »</TD></TR><TR><TD CLASS="quote">2) I noticed some breaking apart of one of the pads near the top edge. Is this anything to worry about? Here is a pic of what I am talking about:</TD></TR></TABLE>
Looks normal to me. My Spec VR's usually look like that. What brand are these?
Also, pads can cause a spongy pedal.
I swear that some pads just get spongy, either glazing reduces the friction or the material gets uneven.
Pad material breaking up:
I swear that some pads just get spongy, either glazing reduces the friction or the material gets uneven.Pad material breaking up:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F »</TD></TR><TR><TD CLASS="quote">
Looks normal to me. My Spec VR's usually look like that. What brand are these?</TD></TR></TABLE>
Yep, Spec VR's... They may be glazed a bit so I may use a little sandpaper on them lightly - I've heard that helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux »</TD></TR><TR><TD CLASS="quote">Yep, Spec VR's... They may be glazed a bit so I may use a little sandpaper on them lightly - I've heard that helps.</TD></TR></TABLE>
Someone that knows better might be able to help, but sure enough, they DO look glazed. There's most of your spongy pedal I bet. They should be better when you're done... hopefully... let us know
Otherwise it's air molecules in between your brake fluid molecules.
I'm betting my pads are glazed based on the pedal feel...
Are they trash now or will some sandpaper fix the problem?
<--- hopes there is a remedy since there is plenty of life left in these pads.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux »</TD></TR><TR><TD CLASS="quote">I'm betting my pads are glazed based on the pedal feel...
<--- hopes there is a remedy since there is plenty of life left in these pads.</TD></TR></TABLE>
no worries, some sandpaper and they will be good to go...
as for Mr. Fries pads, those look ashed, which there is no hope for
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR »</TD></TR><TR><TD CLASS="quote">as for Mr. Fries pads, those look ashed, which there is no hope for
Did someone say HOPE?! My brakes now have hope. We'll see if these ghetto ducts survive (new from yesterday... the ones I did yesterday didn't clear the wheels.)
</TD></TR></TABLE>Did someone say HOPE?! My brakes now have hope. We'll see if these ghetto ducts survive (new from yesterday... the ones I did yesterday didn't clear the wheels.)
uneek360
Apr 13, 2007 07:19 PM
