Brake System Inspection - Pad Questions...
Old 05-24-2005, 04:43 PM
Flux's Avatar
Default Brake System Inspection - Pad Questions...
The mushy brake pedal has prompted me to do a full brake inspection, thinking that the soft pedal may be more than needing to bleed the brakes (again).
My rear pads are toast (time to call Andie). I know lots of people are running the Cobalt Spec-GT in the rear with the Spec VR up front so I thought I would give those a try (had the Endless CCX).
I did noticed some weirdness in the front pads.
1) One of the pads from each front corner is worn more than the other from the same corner (I don't know if it is the inside or outside pad). Is this normal? Should I 'rotate' them? Which side normally wears faster?
2) I noticed some breaking apart of one of the pads near the top edge. Is this anything to worry about? Here is a pic of what I am talking about:
Thanks for your help guys.
Old 05-24-2005, 04:46 PM
B2FiNiTY's Avatar
Default Re: Brake System Inspection - Pad Questions... (Flux)
That wear is normal and yes you can rotate it.
Old 05-24-2005, 05:03 PM
Flux's Avatar
Default Re: Brake System Inspection - Pad Questions... (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">That wear is normal and yes you can rotate it. </TD></TR></TABLE>
Do you know which side normally wears faster? I don't want to accidently jsut put them in the same way they were...
Old 05-24-2005, 05:15 PM
BlueR's Avatar
the inside pad always wear faster...
part of that is bc most people do not remove the dust shield
the uneven pad wear can be taken care of by purchasing some sp00mage
Old 05-24-2005, 05:49 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux &raquo;</TD></TR><TR><TD CLASS="quote">2) I noticed some breaking apart of one of the pads near the top edge. Is this anything to worry about? Here is a pic of what I am talking about:</TD></TR></TABLE>
Looks normal to me. My Spec VR's usually look like that. What brand are these?
Also, pads can cause a spongy pedal. I swear that some pads just get spongy, either glazing reduces the friction or the material gets uneven.
Pad material breaking up:
Old 05-24-2005, 06:03 PM
Flux's Avatar
Default Re: Brake System Inspection - Pad Questions... (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
Looks normal to me. My Spec VR's usually look like that. What brand are these?</TD></TR></TABLE>
Yep, Spec VR's... They may be glazed a bit so I may use a little sandpaper on them lightly - I've heard that helps.
Old 05-24-2005, 06:10 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux &raquo;</TD></TR><TR><TD CLASS="quote">Yep, Spec VR's... They may be glazed a bit so I may use a little sandpaper on them lightly - I've heard that helps.</TD></TR></TABLE>
Someone that knows better might be able to help, but sure enough, they DO look glazed. There's most of your spongy pedal I bet. They should be better when you're done... hopefully... let us know Otherwise it's air molecules in between your brake fluid molecules.
Old 05-24-2005, 07:15 PM
Flux's Avatar
I'm betting my pads are glazed based on the pedal feel...
Are they trash now or will some sandpaper fix the problem?
&lt;--- hopes there is a remedy since there is plenty of life left in these pads.
Old 05-24-2005, 07:23 PM
cryptikman's Avatar
Reminds me that I need some new pads again.
Old 05-24-2005, 07:37 PM
BlueR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux &raquo;</TD></TR><TR><TD CLASS="quote">I'm betting my pads are glazed based on the pedal feel...
&lt;--- hopes there is a remedy since there is plenty of life left in these pads.</TD></TR></TABLE>
no worries, some sandpaper and they will be good to go...
as for Mr. Fries pads, those look ashed, which there is no hope for
Old 05-24-2005, 08:15 PM
Chris F's Avatar
Default Re: Brake System Inspection - Pad Questions... (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">as for Mr. Fries pads, those look ashed, which there is no hope for </TD></TR></TABLE>
Did someone say HOPE?! My brakes now have hope. We'll see if these ghetto ducts survive (new from yesterday... the ones I did yesterday didn't clear the wheels.)
mickey513
11-16-2018 03:56 PM
jlowellintegra
12-23-2010 09:46 PM
uneek360
04-13-2007 07:19 PM
chuckm1020
05-24-2004 10:01 AM
buskethead
10-23-2002 11:23 AM
Quick Reply: Brake System Inspection - Pad Questions...
