Turbo for my R
Old Feb 6, 2002 | 01:09 PM
rookieR's Avatar
Default Turbo for my R
I just got my ITR a few months ago and now I'm ready to drop in a turbo. Overall, what kind of turbo would be the most beneficial as far as response, torque, peak hp and reliability. T3, T4, T3/T4, GT, etc.?
Old Feb 6, 2002 | 01:17 PM
DLB1994's Avatar
Default Re: Turbo for my R (rookieR)
get a drag3 or revhard kit with a hondata stage 3 or 4 and a inline pro head gasket u will be good up to about 350hp on a stock b18c5
austrian type-R's Avatar
in the upper right corner is a search button.
T3/4 hybrid is the way to go. Why don´t just buy a DRAG III kit, standalone ECU and 440cc injectors and be happy?
Old Feb 6, 2002 | 01:18 PM
Type-ARR's Avatar
No turbo is good for that, just get a JRSC
Turbo lag =
Old Feb 6, 2002 | 01:19 PM
Type-ARR's Avatar
Default Re: Turbo for my R (DLB1994)
ummm....no
Old Feb 6, 2002 | 01:21 PM
D-SPEED's Avatar
Default Re: Turbo for my R (TurboR481)
DRAG kits are bunk.
Old Feb 6, 2002 | 01:38 PM
DIRep972's Avatar
Smarter than you
another vote for Drag 3 w/ hondata and inline pro headgasket..
Old Feb 6, 2002 | 02:01 PM
b18cTurbo's Avatar
Default Re: Turbo for my R (DIRep972)
i use to fi my itr itr make big hp on fi but tuning is the key whit your 10.6 compression you cant go upper 7 psi on 91 gaz pump whit lotes of retard , mine was at 8 deg.
an i/c is a must whit your stock compression or youl blow for sure.
Old Feb 6, 2002 | 02:08 PM
TurboIntegra's Avatar
Default Re: Turbo for my R (mikvtec)
I have:
Type R
Drag Gen III
Headgasket
Hondata 2b
Dyno =322hp
Old Feb 6, 2002 | 02:51 PM
rookieR's Avatar
Default Re: Turbo for my R (D-SPEED)
Then what do you suggest?
Old Feb 6, 2002 | 02:52 PM
rookieR's Avatar
Why not? What do you think I should go with?
Old Feb 6, 2002 | 02:54 PM
rookieR's Avatar
Default Re: Turbo for my R (austrian ITR)
I'm sorry, but what is the difference between a standalone ECU and the Hondata stage 3 or 4?
Thanks for the help!!
Old Feb 6, 2002 | 02:58 PM
rookieR's Avatar
Thanks so much for the reply. But also, if I lower the CR to 9.0:1 would I be able to raise my boost level. If so, what kind of modifacations would I need to think about doing?
Old Feb 6, 2002 | 03:04 PM
rookieR's Avatar
Old Feb 6, 2002 | 03:19 PM
DIRep972's Avatar
Smarter than you
lower the compression to 9.6:1
tune it with the hondata which works just like a stand alone except its cheaper and u dont have to work from scratch..
Old Feb 6, 2002 | 03:29 PM
threatcon13's Avatar
New User
actually when you lower the compression you have to turn up the boost to make up for lost power.
Old Feb 6, 2002 | 08:51 PM
Pinhead's Avatar
New User
Default Re: Turbo for my R (turbo01gsr)
come on now guyz i've heard of people tuning really good with a hondata and 8psi of boost on a stock type R other than a new headgasket and blowing the crap out of their motors.....turbo's are too much upkeep and not very fast on the street IMO
they do sound very intimidating though
Old Feb 6, 2002 | 09:38 PM
Default Re: Turbo for my R (typerman1358)
WOW That was one of the dumbest things I have ever heard....
Apparently the C5 Vette I KILLED the other night is slow because my turbo integra is "not very fast on the street"....
And turbo cars are not hard to upkeep IF properly installed and TUNED.
[Modified by TurboIntegra, 10:39 PM 2/6/2002]
Old Feb 6, 2002 | 09:40 PM
D-SPEED's Avatar
custom kit how about do it right the first time
Old Feb 6, 2002 | 10:11 PM
G_Man604's Avatar
yeah..don't cheap out on ur car
Old Feb 7, 2002 | 12:33 AM
turbopimp's Avatar
Another vote for DRAG 3 +Hondata...save yourself a lot of time, grief, and money...
Old Feb 7, 2002 | 05:43 AM
b18b98's Avatar
Default Re: Turbo for my R (turbopimp)
i say get a set of Toda spec Bs, cam gears, valves, valve springs, retainers and hondata....oops..wrong topic..
but i do give another vote on a drag3/revhard with hondata....be sure to put in a good clutch to hold the power
Old Feb 7, 2002 | 08:53 AM
DIRep972's Avatar
Smarter than you
DO I HAVE TO SLAP YOU BOI! ever raced a turbo integra! ooooooooohhhh I just wanna hit u! Damn, go back to your typeR forum and talk about autoXing..
Old Feb 7, 2002 | 09:58 AM
Type-ARR's Avatar
autoXing......ahahahahahahhahahahah autoXing =
Old Feb 7, 2002 | 10:03 AM
Adi Radoncic's Avatar
On Fire!
You just got another vote for Drag lll, Hondata, Inlinepro headgasket!!
StevieR
Feb 15, 2011 08:15 PM
hondahatch741
May 30, 2005 12:36 PM
See Are X
Nov 1, 2004 11:27 AM
