Turbo for my R
Turbo for my R
I just got my ITR a few months ago and now I'm ready to drop in a turbo. Overall, what kind of turbo would be the most beneficial as far as response, torque, peak hp and reliability. T3, T4, T3/T4, GT, etc.?
Re: Turbo for my R (rookieR)
get a drag3 or revhard kit with a hondata stage 3 or 4 and a inline pro head gasket u will be good up to about 350hp on a stock b18c5
in the upper right corner is a search button.
T3/4 hybrid is the way to go. Why don´t just buy a DRAG III kit, standalone ECU and 440cc injectors and be happy?
Turbo lag =
Re: Turbo for my R (DLB1994)
Re: Turbo for my R (DIRep972)
i use to fi my itr itr make big hp on fi but tuning is the key whit your 10.6 compression you cant go upper 7 psi on 91 gaz pump whit lotes of retard , mine was at 8 deg.
an i/c is a must whit your stock compression or youl blow for sure.
Thanks so much for the reply. But also, if I lower the CR to 9.0:1 would I be able to raise my boost level. If so, what kind of modifacations would I need to think about doing?
Smarter than you
lower the compression to 9.6:1
tune it with the hondata which works just like a stand alone except its cheaper and u dont have to work from scratch..
New User
Re: Turbo for my R (turbo01gsr)
come on now guyz i've heard of people tuning really good with a hondata and 8psi of boost on a stock type R other than a new headgasket and blowing the crap out of their motors.....turbo's are too much upkeep and not very fast on the street IMO
they do sound very intimidating though
Re: Turbo for my R (typerman1358)
Apparently the C5 Vette I KILLED the other night is slow because my turbo integra is "not very fast on the street"....
And turbo cars are not hard to upkeep IF properly installed and TUNED.
[Modified by TurboIntegra, 10:39 PM 2/6/2002]
Re: Turbo for my R (turbopimp)
i say get a set of Toda spec Bs, cam gears, valves, valve springs, retainers and hondata....oops..wrong topic..
but i do give another vote on a drag3/revhard with hondata....be sure to put in a good clutch to hold the power
Smarter than you
DO I HAVE TO SLAP YOU BOI! ever raced a turbo integra! ooooooooohhhh I just wanna hit u! Damn, go back to your typeR forum and talk about autoXing..
hondahatch741
05-30-2005 12:36 PM
