cel confusion??
Old May 22, 2005 | 08:35 PM
integravtec96's Avatar
Default cel confusion??
so i have a cel on my h22 civic ek, i have been trying to determine what it means with no luck. I have gone to a dealership and they were unable to read it because the tool didnt recognize the cel. i also tried jumping it with no luck. however, even when the ignition key is turned to the acc mode the light is on... shouldnt it only come on when the car is on?? what could this mean? the car is running a chipped p28 with a p13 program. the engine is obd2 (1997)
Old May 23, 2005 | 10:19 AM
JimBlake's Avatar
Default Re: cel confusion?? (integravtec96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integravtec96 &raquo;</TD></TR><TR><TD CLASS="quote">... however, even when the ignition key is turned to the acc mode the light is on... shouldnt it only come on when the car is on?? what could this mean?</TD></TR></TABLE>Maybe it's not the ECU that's causing the light to come on. The light should have power when it's on, the ECU closes the ground side of the light's circuit. Maybe that wire going to the ECU has rubbed thru & it's shorting to ground somewhere?
alexdog69
Jul 23, 2012 11:03 AM
boostd ls
Oct 4, 2009 09:45 AM
arrocha87
20
May 13, 2009 03:46 PM
integravtec96
May 23, 2005 12:36 PM
