question on engine swap
Old May 22, 2005 | 08:21 PM
racekar's Avatar
Default question on engine swap
just a quick question on pulling an engine out of a civic. can i pull the engine out with shift linkage still on or do i hav eto take it off.. i just dont want to hassel with the pin removal sounds like a pain in the butt.
thanks
Old May 22, 2005 | 08:31 PM
v4lu3s's Avatar
RTFM
if you can drop it out the bottom you can leave the linkage on. out the top its a bit harder unless you ahve a lift and can get teh car high enough.
Old May 22, 2005 | 09:26 PM
racekar's Avatar
sounds kind of hard from the bottom.. i would have to put it on some really lowand jack the car up really high?
Old May 23, 2005 | 05:19 AM
coupe_hybrid's Avatar
Default Re: (racekar)
I've done it from the top before you just gotta be very careful and tilt the motor so the shifter will clear.
Old May 23, 2005 | 11:04 AM
racekar's Avatar
ok thanks guys
Old May 23, 2005 | 11:07 AM
racekar's Avatar
is there anyone in so cal that would help with a engine swap removal and possibly install
How much?
this is more the for guy that wants toinstall the engine swap.
jkmskfk
Feb 6, 2012 11:37 AM
felon-k20
Apr 13, 2007 06:38 PM
carcraft
Apr 19, 2005 05:34 PM
exCiViCex
Feb 18, 2004 06:45 PM
brenerb
Jun 17, 2003 10:52 PM
