Vetec not activating
Old May 22, 2005 | 08:30 AM
Sick EG Will's Avatar
Default Vetec not activating
Thinking of buying a 93 eg w/ a LS/Vetec swap, LS block from a 94 integra gsr and head from a 2000 Si. Only problem with it is the vetec is not activating. Was told he doesn't know why but it may need a knock sensor? hatch still pulls hard but just imagine the vetec activating. All so needs oxygen sensor. Need advice thanks.
Old May 22, 2005 | 09:16 AM
Dc_Ek's Avatar
Default Re: Vetec not activating (Sick EG Will)
Check what ECU is the car using, if she's running on a p28 there's no need for the knock sensor since that ECU doesn't use knock sensor. Check the vtec wiring, is it activating through a RPM Activated Switch, or a toggle switch? Or is it wired up to the ECU OEM style? My advice, borrow a chiped P28 from a friend and go plug it in on the hatch, check if the vtec works!
Let me know! L8R
Old May 22, 2005 | 09:46 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sick EG Will &raquo;</TD></TR><TR><TD CLASS="quote"> vetec</TD></TR></TABLE>
heeeeee
Old May 22, 2005 | 01:00 PM
DelSolDon's Avatar
check oil level, if it is low, VTEC will not work. if it was a knock sensor causing the problem, you would be getting a check engine light. if you are not getting a CEL, then make sure the bulb is there. easiest way is to turn the key to accessory position and the light should light up under all circumstances. if it doesn't, the bulb is either bad or taken out.
Old May 22, 2005 | 01:05 PM
hAILO's Avatar
" LS block from a 94 integra gsr " so is it a ls or a gsr?
Old May 23, 2005 | 03:21 PM
Default Re: Vetec not activating (DelSolDon)
The CEL is on, any other advice
Old May 23, 2005 | 04:10 PM
DelSolDon's Avatar
the CEL is on while the car is running, or when the key is turned to accessory?
Old May 23, 2005 | 04:39 PM
When the car is running.
Old May 23, 2005 | 04:41 PM
DelSolDon's Avatar
check your IM (instant messenger on here, not intake manifold)
Old May 23, 2005 | 04:47 PM
How do you do that ?
Old May 23, 2005 | 08:22 PM
Slow ass EF's Avatar
Vetec Eh?
you have to find out which code is in the computer to get better help.
vtec wont engage without a knock sensor unless you have a chipped ecu
Old May 23, 2005 | 10:24 PM
HoUTX98GSR's Avatar
Default Re: Vetec not activating (LSVTECJay)
wow VETEC... check which code its throwing.. it may be the VTEC ( ) selelnoid. It could also be because hes using an obd2 ecu that doesnt see a knock sensor???
Old May 24, 2005 | 03:06 AM
EFB16ACRX
Guest
Posts: n/a
Default Re: Vetec not activating (HoUTX98GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HoUTX98GSR &raquo;</TD></TR><TR><TD CLASS="quote">wow VETEC... check which code its throwing.. it may be the VTEC ( ) selelnoid. It could also be because hes using an obd2 ecu that doesnt see a knock sensor???</TD></TR></TABLE>solenoid
Old May 24, 2005 | 07:59 AM
Kamin's Avatar
Default Re: Vetec not activating (EFB16ACRX)
its vtec.
first step is to find out why your CEL is on.
here is a vtec troubleshoot.
http://info.honda-tech.com/ind...oting
4drteg54321
Jul 7, 2008 03:09 PM
rusureboutdat
Jul 28, 2004 10:42 PM
Big Dick Bandit
Sep 28, 2003 04:54 PM
16vracer
Apr 15, 2002 02:55 PM
Doctor CorteZ
Feb 7, 2002 04:45 PM
