are the D16Y7 interference engine??
Old May 20, 2005 | 10:36 PM
miguel6632's Avatar
Default are the D16Y7 interference engine??
if my timing belt breaks will it kill my valves and kill my engine,, i searched and found contradicting statments but some were on the d16z6 and d15b? nothing on my engine, thanks
Old May 20, 2005 | 11:58 PM
neutron91's Avatar
Default Re: are the D16Y7 interference engine?? (miguel6632)
every honda engine i know of is an interference engine... theres no way you can tell if you will destroy your motor if your timing belt breaks... its just chance... sometimes you get lucky, sometimes you dont
Old May 21, 2005 | 05:23 AM
Dr. D-Series's Avatar
It is not an interference engine.
Old May 21, 2005 | 06:50 AM
civicboisi's Avatar
Default Re: (Dr. D-Series)
interesting...id like to know too...up for some more backup!
i always thought they were...i could be wrong
Old May 21, 2005 | 06:52 AM
neutron91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr. D-Series &raquo;</TD></TR><TR><TD CLASS="quote">It is not an interference engine.</TD></TR></TABLE>
you sir are wrong... a non interference motor is one where the valves and pistons are unable to come in contact with each other
Old May 21, 2005 | 07:03 AM
Explain how my aem cam gear slipped on a 11:1 compression mini me and I didnt bend a valve.
My pals T belt snapped on the highway, not a bent valve.
Hmm.
Old May 21, 2005 | 07:19 AM
civicboisi's Avatar
luck? 11:1 compression TURBO? nice...
Old May 21, 2005 | 07:54 AM
HiProfile's Avatar
Default Re: (civicboisi)
Slip the belt off, TDC cyl #1, and spin the cam... It's conveivable that the cam could come to rest w/o any valves at full lift. Not only does it spin half speed of the crank, but theres not much rotating mass & good amount of opposition to rotation.
Old May 21, 2005 | 07:56 AM
Do_Ster's Avatar
i was under the assumption that anything with a timing belt was an interference engine while anything with a timing chain, is non-interference. someone correct me if i'm, which i'm probably am lol
Old May 21, 2005 | 08:11 AM
Haha I wish I had boosted the 11:1 vtec motor.
But a bad headgasket hydrolocked the motor, destroyed the head and block.
I ran 13.7 on a 10.1:1 non vtec 1.5
Old May 21, 2005 | 10:34 AM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr. D-Series &raquo;</TD></TR><TR><TD CLASS="quote">Explain how my aem cam gear slipped on a 11:1 compression mini me and I didnt bend a valve.
Hmm.</TD></TR></TABLE>
Explain to me how my wife broke the timing belt in her 94 GSR and didn't bend a single valve? Had the head checked and all. You cannot tell me that isn't an interfearance engine. Do me a favor, call honda and run your little "theroy" past them, see what they say. I can gaurantee you that engine *IS* an interfearance engine.
Old May 21, 2005 | 04:07 PM
You my friend. Get mad way too easily.
I am saying this because of all the different occassions its happened on. And no ill effects.
Not just 1. Or just 1 of my own.
I can be wrong. It is possible. I am human. Relax.
Old May 21, 2005 | 04:25 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr. D-Series &raquo;</TD></TR><TR><TD CLASS="quote">You my friend. Get mad way too easily.
I can be wrong. It is possible. I am human. Relax.</TD></TR></TABLE>
I wasn't mad. I'm relaxed.
Old May 21, 2005 | 04:42 PM
Revolver's Avatar
Just as long as you know that you were wrong. It is in fact an interference engine.
Old May 21, 2005 | 05:07 PM
It happens.
Cant know it all.
I just know my own personal experience.
Old May 26, 2005 | 07:39 AM
DOHCVBEP's Avatar
Default Re: (Revolver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revolver &raquo;</TD></TR><TR><TD CLASS="quote">
Just as long as you know that you were wrong. It is in fact an interference engine. </TD></TR></TABLE>
cnrtool
Sep 22, 2009 01:38 PM
NormS
Feb 20, 2007 12:05 PM
T-78RX7
Sep 3, 2005 06:09 PM
EK FLY
Apr 18, 2005 11:46 AM
dpires73
Feb 11, 2005 09:24 PM
