HELP....WATER IN MY DEL SOL!!!!!!!!!!!!
Old May 20, 2005 | 02:01 PM
NosCivic01's Avatar
Default HELP....WATER IN MY DEL SOL!!!!!!!!!!!!
everytime it rains i get water in my car but it leaks a little. now wen i drive it i hear water goin back n forth in the body of the car behind me. my trunk is dry n my inside is dry so its gota b between the trunk n inside of the car. how can i get this water out n possibly prevent this from happening???? PLEASE HELP
Old May 20, 2005 | 02:14 PM
HATCHingMN's Avatar
Default Re: HELP....WATER IN MY DEL SOL!!!!!!!!!!!! (NosCivic01)
is your delsol Targa top??
it might be leaking for the weather seal there,
the moving water may be in the trunk where the spare tire is at.
Old May 20, 2005 | 02:39 PM
KtHaNxBai's Avatar
Default Re: HELP....WATER IN MY DEL SOL!!!!!!!!!!!! (HATCHingMN)
grab a shop vac and get that watta out, be4 it starts to stink and get mildew.
Old May 20, 2005 | 03:37 PM
NosCivic01's Avatar
Default Re: HELP....WATER IN MY DEL SOL!!!!!!!!!!!! (galaxykid70)
its the removable hard top. and there is no water in the trunk wea the spare is at. its behind that i think. i dono how to get it out. n i dont want the body to eventually rust
Old May 20, 2005 | 03:42 PM
Big_Bird's Avatar
if there is not water in the trunk and the carpets are dry then the water is probable in where the rear window rolls down, the drains are probably plugged. The only way to fix it is to either put the car on a hoist and take compressed air and blow back up through the drains or to remove the panel that holds the window and then blow the drains out that way.
Old May 20, 2005 | 03:50 PM
crvtecwidebody's Avatar
Default Re: (Big_Bird)
The drain holes for your electric rear window compartment are clogged up.
You need to take the rear window assembly apart and clean the drain tubes in the rear window compartment.
Or if it has 2/3 of a tank of gas it makes similar noise, but trust me it is clogged drain tubes.
-David-
Old May 20, 2005 | 03:55 PM
KillBot's Avatar
One of the teamdelsol websites has a step-by-step how to for this problem.
Jota
Apr 11, 2016 07:22 PM
whokidd
22
Feb 24, 2011 02:36 PM
Mike Polinder
Jan 13, 2011 01:23 PM
miubhi856
10
Dec 16, 2007 02:26 AM
^LORTA^RACING
11
Sep 30, 2005 07:18 AM
