input shaft bearing for b16 tranny y21
Old May 20, 2005 | 01:49 PM
komat's Avatar
Default input shaft bearing for b16 tranny y21
i have a jdm b16a with a y21 tranny on it
the input shaft bearing needs to be replaced
can someone give me the link to the part from http://www.slhondaparts.com
i cant seem to find it on the web site
Old May 20, 2005 | 02:44 PM
komat's Avatar
Default Re: input shaft bearing for b16 tranny y21 (komat)
weee the isb is owning my tranny
Old May 20, 2005 | 08:46 PM
komat's Avatar
bump!
Old May 22, 2005 | 12:13 AM
komat's Avatar
i think its this
http://www.slhondaparts.com/br...1-003
can anyone tell me if this is the correct one
Old May 22, 2005 | 12:38 AM
fastrunner's Avatar
it is 13 I believe. it has to be an extended bearing, if you look at 13 in the diagram it is gonna allow the shaft to slide through it while spinning. I may be wrong but that logic from the diagram you presented would make the most sense. I am not a honda mechanic.
Old May 22, 2005 | 01:41 AM
komat's Avatar
Default Re: input shaft bearing for b16 tranny y21 (fastrunner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastrunner &raquo;</TD></TR><TR><TD CLASS="quote">it is 13 I believe. it has to be an extended bearing, if you look at 13 in the diagram it is gonna allow the shaft to slide through it while spinning. I may be wrong but that logic from the diagram you presented would make the most sense. I am not a honda mechanic.</TD></TR></TABLE>
nah thats not hte input shaft bearing
i think its part 11 99% sure but want to be 100%
Old May 22, 2005 | 02:15 AM
MonkeyBoy668's Avatar
Ugh. I've been comparing my Helms to this and now I've got a headache.
Part# 11 is a (28X60X15) bearing, which appears to be the same as what you found. HAP (Majestic) doesn't list the same part#s.
Part# 12 is a (80X40X18) bearing, but I think that's the differential bearing.
Of course, I'm assuming the Y21 and S21 are the same - my Helms lists the B16A2 tranny as an S21, not quite sure where Y21 came from... heck, even the 99-00 Civic Si used an S21... JDM part#?
Modified by MonkeyBoy668 at 5:54 PM 5/22/2005
Old May 22, 2005 | 12:59 PM
komat's Avatar
Default Re: input shaft bearing for b16 tranny y21 (MonkeyBoy668)
part 11 isnt the same thing
that goes into the other shaft counter shaft or whatever is called next to the mainshaft
Old May 22, 2005 | 01:31 PM
No, part#3 & #13 are for the countershaft, which lines up with my exploded diagram (follow the line on that picture to the center seat, that's where the countershaft sits).
The confusing thing in that picture is that they've got the differential on the right side of the picture, if they were lined up left to right based on where they sit in the housing, the differential would be on the left and go into the recessed transmission hole on the left.
part# 11 is the front mainshaft bearing (input shaft bearing, whatever). It goes into the hole in the housing on the right, which is where the line puts it and where my exploded diagram puts it. It's a bearing and it seats around the input shaft...
Modified by MonkeyBoy668 at 5:55 PM 5/22/2005
Old May 22, 2005 | 02:43 PM
Jim Truett's Avatar
#11. 100% sure.
Historyg
Sep 29, 2007 10:46 PM
nsxmatt
16
Apr 5, 2005 06:58 PM
Pengo
Jun 20, 2003 08:52 PM
AlphaKennyWun
Nov 28, 2002 08:29 AM
