is knock to high?
Old May 19, 2005 | 08:55 PM
9341civic's Avatar
Default is knock to high?
Statistics - 2.stf : 0:00 to 3:32.927
Channel Min Time at Min Maximum Time at Max Average
Accel Fuel 0 0:00 2700 0:52.26 27.357
Air Temp 32 3:32.92 125.6 1:18.6 118.44
Boost WG Out 0 0:00 0 0:00 0
Coolant Temp 32 3:32.92 194 0:24.1 186.83
Engine Load -12.987 2:55.34 7.4427 2:36.28 -7.4564
Engine Speed 907.81 3:28.78 7386.7 2:30.88 3655.4
Fuel Inj #01 Pulse 615 2:55.14 12130 2:29.24 3073.1
Fuel Trim (Accel) 0 0:00 2700 0:52.26 27.357
Idle Learned Value -4.2969 0:04.06 0 0:16.64 -0.29942
Ign Timing -17 3:32.92 34.68 0:51.66 29.173
Knock #1 Volts 0 3:32.92 4.4727 0:51.28 0.26938
Knock #2 Volts 0 3:32.92 0.019531 0:00 0.019529
O2 #1 7.32 3:32.92 12.181 0:18.38 10.688
O2 #1 FB Value 0 0:00 0 0:00 0
O2 #2 7.32 3:32.92 8.4638 0:00 8.4629
Stat Cranking 0 0:00 0 0:00 0
Stat Running 1 0:00 1 0:00 1
Stat Sync'd 1 0:00 1 0:00 1
Status #1 52 0:25.52 244 0:00 197.79
Throttle 0 0:58.9 89.377 2:42.84 15.631
Vehicle Speed 0 0:00 109.6 2:44.74 57.389
Old May 20, 2005 | 10:36 PM
mtber's Avatar
Default Re: is knock to high? (9341civic)
That factory knock sensor is useless.
Old May 21, 2005 | 02:38 PM
9341civic's Avatar
Default Re: is knock to high? (mtber)
who makes a good aftermarket knock sensor?
Old May 21, 2005 | 03:25 PM
LSVTEC 91 Civic's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9341civic &raquo;</TD></TR><TR><TD CLASS="quote">who makes a good aftermarket knock sensor?</TD></TR></TABLE>
w3rd.
Old May 23, 2005 | 01:41 AM
9341civic's Avatar
Default Re: is knock to high? (LSVTEC 91 Civic)
Old May 31, 2005 | 06:20 PM
9341civic's Avatar
Old May 31, 2005 | 07:53 PM
builthatch's Avatar
MiG-21 superfan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">That factory knock sensor is useless.</TD></TR></TABLE>no it's not....it's actually pretty buff...if you have the right tools to use it properly....
the Apexi Power FC's knock meter, even the one on the lil' commander is very high resolution, making use is a range of 0-200 using the stock knock sensor and has helped many a user/ tuner.
Old May 31, 2005 | 09:21 PM
littlej72's Avatar
OEM sensor is fine (as astated) it's just the stock ecu is not as...acurate or agresively monitored as the aftermarket set ups, because it is just there if you doof and put crap gas in, it will attempt to compensate to prevent immediate severe engine damage. J&S knockgaurd used to be one of the better stand alone knock sytems.
Old Jun 1, 2005 | 02:30 AM
hondaguyef's Avatar
Default Re: is knock to high? (devnull)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devnull &raquo;</TD></TR><TR><TD CLASS="quote">
The factory knock sensor works great and is very useful esp. when calibrated correctly. Check out the aem forums, you can make your own base lines for the knock sensor so that the aem ems can use it accurately.</TD></TR></TABLE>
Good info. I'll have to go check that out. An AEM EMS may be in my fuutre
Old Jun 1, 2005 | 06:47 AM
builthatch's Avatar
MiG-21 superfan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devnull &raquo;</TD></TR><TR><TD CLASS="quote">I personally like to hook up an amp and head phones to the knock sensor.</TD></TR></TABLE>
...this can get tedious hooking it up vs. having a nice knock meter online all the time, however, it does work for sure.
rovafa2002
Apr 25, 2013 10:38 AM
BlowenGT
Apr 4, 2008 04:17 PM
BlowenGT
Apr 3, 2008 03:10 PM
untitledsn41
Jul 30, 2004 04:48 AM
tysir
Jul 31, 2001 06:54 PM
