Reverse Indigo Guages? Ok got them so how to make them work
Old May 19, 2005 | 08:32 PM
A-busive's Avatar
Default Reverse Indiglo Guages? Ok got them so how to make them work
Ok guys i have everything hooked up but then i have a red and black wire left what the hell do i do with these..A diagram would be even very helpful
Old May 19, 2005 | 08:35 PM
redcivic777's Avatar
Default Re: Reverse Indigo Guages? Ok got them so how to make them work (A-busive)
red = power black = ground
Old May 19, 2005 | 08:40 PM
A-busive's Avatar
Default Re: Reverse Indigo Guages? Ok got them so how to make them work (redcivic777)
Ok so can i hook them up where my dimmer is?
Old May 19, 2005 | 09:00 PM
Deemeetree's Avatar
Electrician
Get a circuit/voltage tester. The basic one that lights up when there is a voltage reading (automotive 12v).
Now, pull the cluster out of the dash. Grab the harness that connects to the cluster. Now, go one by one and touch the pins on the harnesses. Make sure that you don't tap into one that has a voltage reading with the ignition OFF. Mark which ones have a reading so you DON'T use them.
Now, place the ignition key to the ON position, don't start the car. Now, go one by one again and check which ones carry a voltage signal. This will be your 12v power. Tap into the wire and off you go.
Lighting. Turn on your low beams. Go one by one again and mark which ones have a voltage signal. Now, turn on your high beams, make sure the ones that carry a 12v signal when the low beams are on also carry one when the high beams are on aswell. Tap into the line and off you go.
Old May 19, 2005 | 09:07 PM
A-busive's Avatar
Default Re: (Dimitri_EG8 a.k.a. Dimi)
11.WIRING THE GAUGES: I wired mine direct to the gauge cluster. This was when my gauge goes on my indiglo's too. I did this by placing the ground (black wire) under a bolt connected to the frame the hot wire (red) I placed in the fuse spot for the gauge cluster (removed fuse wrapped wire around metal of the fuse then replaced fuse) now just set the control where you want it and you are done!
Its sound simple here but what does he mean by this part (I placed in the fuse spot for the gauge cluster (removed fuse wrapped wire around metal of the fuse then replaced fuse)
Old May 20, 2005 | 05:26 AM
A-busive's Avatar
Default Re: Reverse Indiglo Guages? Ok got them so how to make them work (A-busive)
Modified by A-busive at 12:47 PM 5/20/2005
Old May 20, 2005 | 09:48 AM
A-busive's Avatar
Hellpp
Old May 20, 2005 | 10:54 AM
i grounds the black wire and the red wire i hook up to the red wire to the lighting fuse under the dash
Old May 20, 2005 | 11:05 AM
blurrrcivic94's Avatar
Just splice it to the dimmer wire, then as a ground, find a good out of the way place on the chassis and stick a small bolt in it, then wrap the ground wire around the bolt.. easy as 1-2-3
Old May 20, 2005 | 12:10 PM
A-busive's Avatar
Default Re: (blurrrcivic94)
thanx alot now i get it i wanted to do that to the dimmer but wasnt sure i could
A-busive's Avatar
Default Re: (A-busive)
another thing when i did it...it made a sound
Old May 20, 2005 | 12:12 PM
A-busive's Avatar
and what does it mean by this b/c i have already started this ...(red wire I placed in the fuse spot for the gauge cluster (removed fuse wrapped wire around metal of the fuse then replaced fuse)
Old May 20, 2005 | 12:43 PM
is it a continous tone? cuz' when I had mine, if you listened really closely you could hear a faint noise..
Old May 20, 2005 | 12:45 PM
A-busive's Avatar
Yea a continuos it doesn't fade in and out its like a long whistle but hard to hear
Old May 20, 2005 | 12:46 PM
that means their working
Old May 20, 2005 | 01:13 PM
A-busive's Avatar
Yea i knew that so its ok for it too keep making that whistling noise i heard u se a transmitter idk
Old May 20, 2005 | 06:30 PM
KtHaNxBai's Avatar
that noise can prolly be ur flux capacitor takin a ****,
u might wanna change that soon.
kwae
11
Feb 13, 2014 07:51 AM
boost and bass
Dec 3, 2009 04:41 PM
EcivicG
Jun 12, 2008 08:54 AM
FortunateFool.
Audio / Security / Video
Dec 14, 2007 10:46 AM
