lowering more?
Old May 19, 2005 | 06:51 PM
sebZZ's Avatar
Default lowering more?
well i cant post in the proper forum so here goes:
i have a civic and i recently dropped it by buying lowering springs and had a slapped on. i still looks pretyt high and i was wondering if there was anyway to get it lower. im still running on stock tires/steelies so if i get bigger rims it will probably look lower right? any suggestions since im broke..otherwise id go for the coilovers
Old May 19, 2005 | 06:56 PM
BS 22's Avatar
Default Re: lowering more? (sebZZ)
Ground control coilovers are 200...
papito_85's Avatar
there is no way of going lower. Unless you get some coilovers or cut the springs which i don't recommend.
Old May 19, 2005 | 07:20 PM
JDtiM's Avatar
if you get bigger rims, it'll make your ride higher. i dont recommend cuttin springs either..if i were you, get coilovers that adjust more, slam it, and put a camber kit on also (you dont want butterflying now)
Old May 19, 2005 | 07:36 PM
sebZZ's Avatar
ok so i should just save up for some coil overs then?? god damnit..lol
Old May 19, 2005 | 08:10 PM
killaj12's Avatar
Default Re: lowering more? (BS 22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BS 22 &raquo;</TD></TR><TR><TD CLASS="quote">Ground control coilovers are 200...</TD></TR></TABLE>
where is this ?
everywhere i look its 300+ ...
but then again im looking for the ones that fit koni yellow
Old May 23, 2005 | 09:33 AM
JDtiM's Avatar
Default Re: (sebZZ)
whatever you do, dont buy dropzone!! i made a huge mistake by doing that. go with well-known brands, like Tein or Tokico
Old May 23, 2005 | 10:06 AM
Status Sean's Avatar
Default Re: (JDtiM)
jus save up and buy a coilover setup !
Old May 23, 2005 | 10:26 AM
Chong's Avatar
ballin
Default Re: (rw92civic)
You can either get coilover sleeves, or some different springs with a more aggressive drop.
Old May 23, 2005 | 10:33 AM
cranberry's Avatar
what springs are you using they should tell you what ride hight should be dropped......i have nuespeed racing springs and im dropped a good ways down........im not slammed but im getting teins for that reason.....and the great dd.....just save for you gound controls man....
96CIVICEX
29
May 13, 2009 10:22 AM
4DRmafia
Jul 7, 2006 04:11 PM
EM1FORLIFE.
15
May 31, 2006 04:07 PM
HONDA RR
Suspension & Brakes
16
Mar 22, 2005 10:05 PM
scatuli
Apr 3, 2004 01:55 AM
