92 Civic: No start problem
Old May 19, 2005 | 05:48 PM
Tec Nine's Avatar
Default 92 Civic: No start problem
92 Civic w/ 95 GSR...swapped over 5 years ago, so that's not the issue. Timing belt on the engine replaced about 2 months ago, but that's the only real engine-related repairs I've made since I did my swap.
Anyway, yesterday it wouldn't start as I was leaving work. I turn the ignition key, I hear my fuel pump pressurize, lights, radio, etc, but nothing else..no clicks, no starter, no cranking ,nothing. A couple times while trying this the speedo shot up to 80, then went right back down(!?), but still nothing but dash lights and fuel pump. I did notice the engine seemed to turnover 'slowly' when I left for work, but it fired up so fast I thought it was my imagination. Seems like it was more than that....
Any clues where to look? I checked the batter (12.5v), checked for lose wires, whacked the starter with a hammer...everything that a guy can think of when he's 25 miles from home in the parking lot of his employer.
take care,
Mike
Old May 19, 2005 | 07:03 PM
95DxSi-R2
Guest
Posts: n/a
Default Re: 92 Civic: No start problem (Tec Nine)
bypass the starter relay and see if it starts. don't know where it's at, good luck, or take something metal and touch both posts of the starter, don't be scared either. It wouln't hurt u.
Old May 19, 2005 | 07:53 PM
Bakuryu06's Avatar
Default Re: 92 Civic: No start problem (95DxSi-R2)
I had the same similar problem with my civic, all lights and radio would turn on but when key was turned nothing, found out it was my BATTERY, too much build up, the the current was going through. a SMall bottle of Coke did the job.
Old May 19, 2005 | 08:49 PM
spoolingb20's Avatar
loose ground if your batt. starter, and the car still has power
Old May 19, 2005 | 09:18 PM
Andres-eh2's Avatar
Happened to me 2 weeks ago. Similar prob with the speedo but only once.
Replaced:
- Dizzy Ignitor, nothing
- Replaced with 2 other starters, nothing
- Placed wire from the starter bracket to the neg. batter terminal, BINGO. The chassis to tranny ground went out.
Also try push starting it and see if it turns on to eliminate other probs
Old May 19, 2005 | 09:24 PM
DasaEJ1's Avatar
Default Re: (Andres-eh2)
hmm...so tell me does it crank up at all?? or does it not make it sound when u try to start it up?
Old May 20, 2005 | 02:23 AM
Tec Nine's Avatar
Default Re: (DasaEJ1)
Dasa, it makes no sound at all.
Thanks guys. I'm off to work today, so I'll start checking out all the wires leading from the battery. I'll wait until after work so I don't look like a complete idiot with my tools out in the parking lot!
take care,
Mike
Old May 20, 2005 | 03:02 AM
98oRange's Avatar
Default Re: (Tec Nine)
my sparkies were superfouled when I couldnt get my biatch to start.
Old May 20, 2005 | 07:03 PM
Tec Nine's Avatar
Default Re: (98oRange)
Thanks guys. Bad ground to the tranny, as some of you guessed. With your help I had it running in 15 minutes!
take care,
Mike
Old May 20, 2005 | 07:14 PM
KtHaNxBai's Avatar
another satisfied member
Old May 20, 2005 | 07:48 PM
Andres-eh2's Avatar
i hate when i turns out being little **** like that..
leroy2332
10
Jul 15, 2009 11:08 AM
Twistedframe
Apr 11, 2007 05:10 PM
Scorch7
10
Oct 19, 2005 06:32 PM
JacksColdSweat
Sep 22, 2005 10:43 AM
kelebonan
Jul 12, 2003 06:40 PM
