reset ecu... deck led messed up now
i just finished changing out my knock sensor 2 days ago... so afterwards, i went to reset my ecu... it resetted itself (everything was off as i pulled the clock/radio fuse) , but then my deck's display is all funky now...
everything functions just fine except for the display. it would randomly turn all white... like the brightness/contrast just shot up all the way... and then it would just randomly go back to normal on its own or when i press a button...
blown fuse on the deck? whats the deal? tia guys
this is called "invert mode"........put key in ignition and turn to ACC/on position, hold down source button or whatever button you need to turn off headunit.......then press "5" on the preset number buttons.....you should here a beep.......that should do it............if not try another number button....your model is different from mine.........let me know if it works.......
i have no clue......maybe it's like a screen saver like what you have for your PC monitor.......or pioneer just put it in to **** people off........if you look through your instruction manual it'll have a small blurb about it.............
tip my hat off to you man
... yah i was so happy to fix my bogging/hesitiation problem after changing the ks sensor... that i didnt probably realize my deck was doing that till today heh
thanks again
thanks again
screen saver? thought the purpose of them was to reduce monitor burn from being active/idle too long without use... someone please correct me if im wrong? weird pioneer would equip the hu's with that...
word to that =p
word to that =p
