Computer reset
Old Sep 24, 2002 | 12:11 AM
EndlEEsss's Avatar
Default Computer reset
what is the procedure to reset the computer?
which fuse do i have to pull and hold long does the car have to be off?
thanks
Old Sep 24, 2002 | 12:20 AM
2.2dc2's Avatar
Default Re: Computer reset (tweakmeup)
1. you can start off by a search.
other than that its ecu/hazard fuses. wait like 10 min
2. i could be wrong. but searching always helps
Old Sep 24, 2002 | 12:33 AM
Steve04SVT's Avatar
Simple! With the car on, take the cover off the fuse box on the passenger side of the car just under the cowl. Locate the ECU fuse and the RADIO/BACKUP fuses. Remove them gently with a fuse puller or some pliers. It doesn't matter which one you do first, but the car will turn off. Leave them out for at least 10 seconds. Then, remove your keys from the ignition and replace the fuses in their respective locations. After waiting, turn the car back on; it will stumble at first, but then the ECU will begin to read the sensor info. That's it! Good luck!
Old Sep 25, 2002 | 12:20 PM
greensleeper's Avatar
Default Re: Computer reset (Steve96Accord)
what if you got a bad idle? will that screw up the computer when it 'reboots'?
Old Oct 1, 2002 | 08:27 AM
EndlEEsss's Avatar
Thanks, will try it soon
Old Oct 1, 2002 | 08:48 AM
TouringAccord's Avatar
H-T Order of Merit
This is what I do to reset the ECU.
Step 1 - Turn on the car and warm it up.
Step 2 - Turn off the car (some say to make sure all accessories are off) and disconnect the negative cable from your battery (you will lose your programmed radio stations).
Step 3 - Wait at least 5 minutes, and then reconnect the cable.
Step 4 - Start your car and do not touch the gas.
Step 5 - Let the car run for at least another 5 minutes then turn it off.
Step 6 - You're done, the ECU is now reset and you are ready to go.
Old Oct 1, 2002 | 09:34 AM
SOHCArchangel's Avatar
Default Re: Computer reset (TouringAccord)
nO man,
step 1: eat a big assed burrito
step 2: pull ecu out so it is visable
step 3: lay a toxic gas cloud upon it ^_^
it always resets mine
[Modified by SOHCArchangel, 1:52 PM 10/1/2002]
Old Oct 1, 2002 | 09:40 AM
Brandon's Avatar
Life is Suffering
Default Re: Computer reset (SOHCArchangel)
Just pull the ECU fuse and you should be fine.
Old Oct 2, 2002 | 08:31 AM
EndlEEsss's Avatar
Default Re: Computer reset ( Brandon)
allrightieethennn
should i reset the ecu after i advance the timing?
my guess is yes, what u ppl think?
thanks
NazVil86
Dec 16, 2006 10:41 AM
vinuneuro
Nov 3, 2004 10:04 AM
CivicTypeRP
Sep 16, 2003 05:37 PM
zseeanz
Apr 1, 2003 06:54 PM
SIK IN DA HED
Oct 27, 2002 08:42 PM
