can u test a ecu w/o being in a car?
someone has offered a ecu for very cheap but im thinkin it may not work. is there anyway to tell this w/o being in my car? if i were to plug it in with my d15b7 would it run the motor or would it **** stuff up? kinda need to know asap. thanks
it will work fine. the only real differance is that p28 is for the ex (vtec). so there are outputs for the vtec if you ever convert to it. other than that its the same.
50bicks for a p28 lucky.
I paid $50 for my p28 and it works great. sometimes you just find a good deal. you'll get a cel when you hit vtec rpm range because you don't have the sensors, but other than that it will run your car.
yes it will run your car if the ecu is good. I was making a general statement that obd0's have 2 plugs, obd1's have 3 plugs, and obd2's have 4. I believe there are some hondas in europe or australia that have diff plug setups, but for the most part the harnesses are all interchangable within their obd series.
