i fear that horrible grinding noise when shifting
Old May 18, 2005 | 03:15 PM
berts95ej's Avatar
* B A N N E D *
Default i fear that horrible grinding noise when shifting
hey whats up, im the new guy to the honda tech pages... well anyway a friend told me to keep my eye on my tranny becuase i get a lot of grinding when in first going into 2nd at high rpms, and it almost always grinds going from nuetral to reverse. should i be afraid for my transmission?
Old May 18, 2005 | 03:28 PM
Kyles ej1's Avatar
Default Re: i fear that horrible grinding noise when shifting (berts95eg)
your synchro is prob going out but the reverse is normal, put it in a forward gear before.
i would get gm synchromesh, it got rid of my high rpm 3rd gear grind. keep in mind its just a band aid, not a fix.
how much does it actualy, grind? can u hear it or feel it?
Old May 18, 2005 | 03:38 PM
JDubbs99Civic's Avatar
Default Re: i fear that horrible grinding noise when shifting (93ejay1)
i have that problem as well. when im going into 2nd at high rpm it will grind when i attempt to shift really fast. even if my foot is all the way down on the clutch, it still grinds, its almost like my foot is faster than my clutch. in the same situation, even if i am at high rpm, if i wait just a brief second before going it into 2nd, it engages smoothe, is this for sure a synchro problem? if it is, should i expect bigger tranny problems later? how much to fix this problem? would it just be easier to swap trannys?
Old May 18, 2005 | 03:40 PM
litterbox's Avatar
I am a (Trial User) Army
Default Re: i fear that horrible grinding noise when shifting (JDubbs99Civic)
Try Honda MTF. It's just a bandaid though.
Kyles ej1's Avatar
ITs most likely a synchro problem and yes it will cause bigger problems, like losing that gear totally.
Old May 18, 2005 | 03:46 PM
i have a d16y7 motor, any suggestions on what to do? should i attempt to have this tranny fixed or buy a new one? someone told me the ex tranny is smaller and lighter, maybe that would be the better idea?
Old May 18, 2005 | 03:58 PM
.Kevin.'s Avatar
gezz this seems to be a problem with multiple people, i have the problem to and have had it for awhile, i changed my trany fluid with honda trans fluid and still have it,
Old May 18, 2005 | 04:30 PM
fasthatchb18c1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by berts95eg &raquo;</TD></TR><TR><TD CLASS="quote">hey whats up, im the new guy to the honda tech pages... well anyway a friend told me to keep my eye on my tranny becuase i get a lot of grinding when in first going into 2nd at high rpms, and it almost always grinds going from nuetral to reverse. should i be afraid for my transmission?</TD></TR></TABLE>
Not really your tranny can take a good beating. My last one would gring in third at any RPM unless I just let it slip in by itself. I would recomend shifting slower when at high RPM's so it doesnt get worse, and just get another one you know the syncros are not busted in.
Old May 19, 2005 | 01:19 PM
berts95ej's Avatar
* B A N N E D *
thanks for the info. ill just shift slower, im saving money for a new engine anyway.
Old May 19, 2005 | 01:40 PM
Marauder's Avatar
I had that in my '00 EX, and it went away after I installed a freshly rebuilt tranny.
Quickridez_3
Dec 20, 2006 04:26 PM
Spence
Jul 16, 2006 07:13 AM
RTW DC2R
Sep 5, 2003 07:36 AM
sshaikh01
17
Mar 6, 2003 06:27 PM
is3oo
Jun 6, 2002 10:10 PM
