Help. Clutch went out?
Old May 18, 2005 | 02:09 PM
R.a.w.'s Avatar
Default Help. Clutch went out?
guys my clutch feels like butter and wont go into gear. I didnt do anything wrong, how could this of happend? its a 2000 base prelude with only 53k miles.
i dont know whats wrong or what to do.
Old May 18, 2005 | 02:33 PM
eMpAtHy's Avatar
Default Re: Help. Clutch went out? (KevinZeee)
either the spring popped out..or ur clutch fluid is gone..go check ur clutch fluid
Old May 18, 2005 | 02:36 PM
92hondalude's Avatar
Default Re: Help. Clutch went out? (eMpAtHy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eMpAtHy &raquo;</TD></TR><TR><TD CLASS="quote">or ur clutch fluid is gone</TD></TR></TABLE>
whitch means the master or slave cylinder is shot
Old May 18, 2005 | 03:11 PM
prelittlelude's Avatar
yeah go check the clutch fluid level
if there is no fluid you got air in the line, which means you broke a line or the slave (most likely) or master cylinder went out..
no need to panic , honda-tech is hear to embrace you
Old May 18, 2005 | 03:20 PM
R.a.w.'s Avatar
Default Re: Help. Clutch went out? (prelittlelude)
hey guys i just checked the fluid levels and it was completely empty!
so do i need to pour brake fluid in there?
Old May 18, 2005 | 03:35 PM
R.a.w.'s Avatar
or do i have to buy a new master cylinder? or just refill it and bleed it?
Old May 18, 2005 | 03:41 PM
no you need to find out where its leak out from and fix that first
Jaydeep
Dec 1, 2011 05:35 AM
y-56
Transmission & Drivetrain
Jan 14, 2011 07:04 AM
m3 boostin
May 30, 2007 01:20 PM
7sins
Aug 24, 2006 11:06 PM
buda18
Jul 9, 2003 09:09 AM
