clutch...HELP
clutch...HELP
ok so im not an expert but i didnt think clutches just go out outa nowhere...and thats wut happend to me the other night.....it wasnt engaging like i always has....finally took it home...now when i press the clutch down to try to get it outa my garage...it just stays at the bottom like theres nothing there....i checked my brake fluid....i didnt have ne..oops...but i poured some in now and still the same prob...someone said it could be the master cylinder and if it is, it should be leaking in ur car and u can smell the fluid...but i dont smell nething, but neways if u guys have ne ideas please help me, i wanna drive my baby
thanks guys
thanks guys
My clutch master cylinder leaks and i cant smell the fluid at all, but you can tell by looking by your clutch pedal and if its leaking your carpet would be stained with fluid. It has pretty much destroyed my floor mat :/ Anyways check all your clutch lines and you need to bleed the clutch fluid too b/c now there is air in the line, that is why your clutch still does not work. Get a Haynes manual if u dont know how.
Re: clutch...HELP (buda18)
its right on the front of the tranny, just infront of the radiator, its black and should have a bleed hole on it. Your system needs to be bled and that should help your problem, if not........
Re: clutch...HELP (Moe)
Well unless he was taking out clutch lines or sumthin, the air had to get in there somehow. Probably a big leak somewhere if it drained all in one night.
Re: clutch...HELP (jaxle)
A similar thing happened to me about a year, or so, ago. I bled the system and added more fluid and never had a problem since.... weird, but true.... I thought that I had a leak too, but wanted to see if it would lose pressure again and it never did.
