People With B18b swap into EG need your help with mine.
Old May 17, 2005 | 08:05 PM
92-LS-Civic's Avatar
Default People With B18b swap into EG need your help with mine.
My swap has been running nicely for about 3 months now. But i dont like it feels when i shift. I think my motor mounts are not in that great of shape. Especially the one on the tranny. When i shift it feels like its rocking or shaking back and forth. Right now i only have 4 mounts. 1 top tranny mount, a/c bracket mount, top drivers side and also the rear mount. First question, is there a bracket that will fit for the side tranny mount? Would filling the tranny mount with like 3M window weld stiffen enough to make a differents? or do they make a dampener or something i could get to stiffen it up a bit? thanks alot.
Old May 17, 2005 | 08:09 PM
Motor-Tek's Avatar
could look into some aftermarket mounts like hasport, or some polyurethane inserts I think energy suspension makes them, they're like $40 shipped on ebay last I checked.
Old May 17, 2005 | 08:19 PM
Default Re: (Motor-Tek)
or i am reading about a engine dampener. how much do they usally go for? and where can you find one?
Old May 17, 2005 | 08:30 PM
Andres-eh2's Avatar
I put the energy suspension mount inserts in mine and its stiff like a motha now. Shakes the whole car. Get the front tranny mount on there. I wouldnt invest in the engine damper, fix your existing mounts first
Old May 18, 2005 | 07:46 PM
Default Re: (Andres-eh2)
I was wondering what mount you can use. I tried using the ones i had a d15 front mount, and that didnt work. And i also tried this other mount i got from a friend. And after thinking about it i think it might be from a older integra. Does anyone have a pic of this mount, or one for sell. hit me up with a pm. thanks
Old May 18, 2005 | 07:50 PM
Andres-eh2's Avatar
its an integra mount, im pretty sure all this info was posted in that thread you made several months ago about this swap
Old May 18, 2005 | 07:55 PM
i think i might of just had a older mount i guess. i will have to look into that. As for the inserts, those are just for torque mounts(front tranny, a/c bracket, rear mount) do they make inserts for the upper driver side and upper passenger side? reason i say that is i tried buying some inserts but he said "they dont make those inserts for those mounts" ???
Old May 18, 2005 | 08:31 PM
Andres-eh2's Avatar
i didnt research that too much, i just simply bought the energy ones, its more than enough, trust me
Old May 18, 2005 | 09:28 PM
90civichb's Avatar
the front tranny mount needs to be from a 94+ integra. You will need only the actual arm itself. The bracket and bushing that bolts to the frame rail can stay the same.
I did this swap on my del sol. I used All the integra mounts. Worked Great. No hard shifting either..
Good Luck
prjdmek
Jun 2, 2010 07:40 PM
hatchyksp
21
Mar 3, 2009 03:04 PM
Electron Eg
Nov 15, 2008 11:58 PM
97civicdx
Feb 9, 2005 12:32 PM
Skyllz
Sep 13, 2003 11:45 AM
