ITR Dash Harness/Fuel Gauge help! need good input!
Would anyone happen to have a wiring diagram for the cluster wiring off of a '98 DC2? I replaced my cut Dash harness when I rebuilt my '98 ITR with supposedly a '98 DC2 dash harness, but my gas gauge needle doesnt move.
The interesting part is that My seatbelt light is allways on and when I fill my gas tank up my seatbelt light gets real bright. When my tank gets low, the light goes dim. Ive even disconnected the seatbelt plug underneith the seat and it still stays on leading me to believe that these two wires are switched at the plug. My friend tells me I can swap the wires at the fuse box instead of behind the cluster but I dont know which two to swap.
So can anyone post a wiring diagram and show me how to swap these two wires?
TIA Gil
TIA Gil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo »</TD></TR><TR><TD CLASS="quote">Was the cluster changed?</TD></TR></TABLE>
well I rebuilt a complete stolem recovery and replaced the cluster with a USDM '98 ITR cluster. Interestingly I installed a '95 GSR cluster and the fuel gauge worked but the cluster flashed all crazy when I turned on the turn signals. I really think just these two wires are switched, maybe the owner of the dash harness before me swapped them to run a '96 ITR spec cluster or something?
try a 96 (manual tranny)integra cluster and transfer the green film over to the cluster you are using now.
the green film on the 98 spec cluster you have could have been switched to a obd1 version.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b_cruz »</TD></TR><TR><TD CLASS="quote">try a 96 (manual tranny)integra cluster and transfer the green film over to the cluster you are using now.
the green film on the 98 spec cluster you have could have been switched to a obd1 version.</TD></TR></TABLE>
is the '96-97 different than the 94-95 cluster?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GUILOTINE »</TD></TR><TR><TD CLASS="quote">
is the '96-97 different than the 94-95 cluster?</TD></TR></TABLE>
the green film is.
the green film is.
the green film is.</TD></TR></TABLE>
ohh so if 98+ and 94-95 doesn't work...it must be a 96-97 dash harness correct?
ohh so if 98+ and 94-95 doesn't work...it must be a 96-97 dash harness correct?</TD></TR></TABLE>
i had to swap the green film as well on my ukdm cluster, the engine temp and fuel gauges wouldn't work at all before
ATgrills.com
Honda S2000
Mar 1, 2008 07:57 AM
SpdFrk
Jan 13, 2003 10:49 PM
