Weird problem concerning my itr dash w/cluster..
need help-concerning my itr dash w/cluster..
okay i bought a itr dash that inlcuded everything with it(cluster, heater controls, vents...etc) So when i wanted to hook up the cluter, i found out that there is no wiring for the rpm part of the cluster???? The fuel, speed, and temp are there but no rpm wiring. All the other wires hook up to the heater controls, hazzards and rear windows defroger. So i know that this is a integra wiring harness.
Anyways my question is which wiring harness can i use that will hookup to my 92 civic with a itr dash with itr cluster?
Also does the 96 honda civic si(Canadian version) have the rpm tach?? and will i be able to use it for my dash and cluster?
Thanks.
[Modified by SpdFrk, 6:21 AM 1/14/2003]
Thanks.
Re: need help-concerning my itr dash w/cluster.. (SpdFrk)
talk to migs about this.. i believe its 98+ teg clusters got the rpm signal from the ecu not the distributor.. you willl need to replace the wire harness i think.. also user Laim has done this swap and may know more about it
ATgrills.com
Honda S2000
03-01-2008 07:57 AM
AIWFCIATR
09-24-2004 12:37 AM
Black 2K
05-17-2003 10:34 AM
