Dash/Electrical Problem
Old Oct 23, 2008 | 04:44 PM
91Hatcher's Avatar
Default Dash/Electrical Problem
I just picked up a 91 si hatch. and for some reason the only gauge that gives me any sort of reading is my temp gauge. no speed, nothing so im thinking its part of the wiring harness myself. and i have a 5th generation si gauge cluster that i put in and it still didnt work. and i replaced the speedometer cable but still nothing + the newer gauge cluster has addtional plug wires that come off of them and they need to be wired into the harness cause there is no space for them to go into. is this something im going to have to put it in the shop for? or can i order new dash harness and other wiring harnesses i need somewhere?
thanks, Casey
Old Oct 23, 2008 | 08:49 PM
salbaje's Avatar
Default Re: Dash/Electrical Problem (91Hatcher)
did you check fuses?
Old Oct 24, 2008 | 09:54 PM
91Hatcher's Avatar
yep and i think im gunna have to replace the fuses and some wiring harnesses under the hood cause the all have that gunk crap in the clips and fuse ports!!! ugh!!
mtflyboy25
Aug 24, 2011 06:00 AM
91Hatcher
Oct 26, 2008 10:48 PM
sohcdestruction
Feb 14, 2008 12:36 PM
bluecivic05
Jun 17, 2006 06:01 AM
bluecivic05
Apr 27, 2006 01:39 PM
