help!!! ASAP, i need to get my hatch running (distributor)
i finnally got my swap into my 91 hatch. I put a OBD-2 (second gen.) dohc zc in it, and swap my car over to OBD-2. my problem is that i am not getting any spark. i checked my wiring, got all of that straight, so i took of the the dizzy so i could swap out the coil with another obd-2 coil my friend has. when i took the cap off i noticed that the coil had been taken out before because the screws were stripped along with a few others inside the dizzy. so i had to drill the screws out and now i have metal shavings on evrything that is magnetic inside the dizzy!!! WTF do i do now? i have spare screws but i don't want to put it all back together with metal shavings all in my dizzy. I tried using a magnet but it didn't get he ones that are on other magnetic parts in the dizzy. i got the motor from Hmotorsonline.com, and their motors come with a start up warranty and the distributor not working should deffinatly be covered under that right?. does anyone have any experince with them as far as the warranty? any info would be greatly appreciated because i want to get my car running, i am sure you all understand that. thanks again.
BTW: is there any dizzy that is interchangable with the OBD-2 dohc zc dizzy. if not where can i get a new if i have to?
sidock
Jun 24, 2011 09:14 AM
99EX_GLB
Oct 19, 2006 08:57 PM
Stebo77
Dec 16, 2002 01:10 PM
