Distributor swapping HELP
Old May 4, 2016 | 01:12 PM
RyanWhite's Avatar
Default Distributor swapping HELP
So my distributor went on my b16a, was a TD44U Dizzy. My local scrap yard has a TD41U dizzy, the houseing is almost identical but not quite so it wont mount up. Does it have the same internals as the TD44U? Cause if so i can just swap the internals over to my TD44U housing.
Thanks!
Old May 6, 2016 | 02:41 AM
holmesnmanny's Avatar
Default Re: Distributor swapping HELP
the 90-91 honda accord uses the same cap, rotor, and coil. I can't say for sure the rest but it's likely it's usable.
It might be a direct swap, but this assumes your car is obd1
Tdemsko
Apr 7, 2005 08:20 AM
mjrage
Jun 5, 2004 08:03 AM
