civic dx with gsr swap PROBLEMS! Trying to Narrow down the possiblities, what else
Old May 16, 2005 | 09:43 PM
MA_Tuning's Avatar
Default civic dx with gsr swap PROBLEMS! Trying to Narrow down the possiblities, what else
Ok, Im doing a gsr swap into a eg cx hatch (Canadian model apparently)
We've used a 92-95 civic harness off of a lx model, all plugs align no problem there.
Only code it's throwing is a 21 (vtec noid)
It's not starting, it turns over only! We had a bad injector so I changed it out, then I saw that the o2 sensor wasn't hooked up, so I did that
I did a cel check hoping to narrow down the problem, but it's only giving me one code, and I've ran a car without vtec hooked up, so Im doubting that it has to be hooked up for it to start right????
I will wire it up once it starts, is there anything else I should check or do
aim mrmboost
if you can help out and have time,
Thanks in advance for your help
Ek Hatches
Nov 25, 2012 07:05 AM
canospeed200
Jun 22, 2010 07:28 PM
chevyluver85
Dec 24, 2008 09:32 AM
IpatXcoreI
May 22, 2006 01:14 PM
milo
Dec 5, 2001 06:27 PM
