problems with swap
Old Jun 16, 2009 | 02:42 AM
canospeed200's Avatar
Default problems with swap
well i just finish doing a swap with my freind he had a 2000 gsr and desided to order a 96 jdm itr engine.We did the swap got the ecu adapter put a chip ecu and now we are getting a checkengine light.Also when it revs up to about 6000 its starts jerking and shuts off.I can't get any codes out of the jdm ecu but if i put the gsr one i get 1337 and 1259 and i cant fine what those are .PLEASE SOMEBODY HELP!!!!!!!!
Old Jun 16, 2009 | 03:11 AM
U.S. Soldier's Avatar
American Extremist
Default Re: problems with swap
Cel Code 1259 is a problem with VTEC. p-1259 is "VTEC system malfunction. Cel Code 1337 is (RPM) Fluctuation Sensor No Signal. Here is a list of the ECU Codes.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-ecu-codes-everyone-682412/
Hope that helps, somewhat.
Old Jun 16, 2009 | 05:17 PM
ok well thats a start thanks for the help man am going to get at it
Old Jun 16, 2009 | 06:44 PM
dvs94Teg's Avatar
From: NORCAL Salinas Valley to Monterey Bay Area 831 CA
exactly how did you wire vtec?
Old Jun 17, 2009 | 05:17 PM
well i didnt wire the vtec being that it was a gsr so it alrady had the plug. but what is funny is that a plug in a code scanner and ran the car and it ran fine then i took the scaner off and the car started having problems again.the vtec wont kick in with out the scanner being hook up and it sputters can somebody help!!!!!
Old Jun 22, 2010 | 07:28 PM
cowsrfuntoday's Avatar
I have a JDM GSR in my EK and ran into the same problem. The JDM engines are actually missing a sensor on the vtec solenoid. That is why the JDM ecu can't isnt pulling anything up. I jus replaced it with the USDM solenoid. I am not sure what the other code was but I know for my swap we had to cut a wire and combine it with another sensor for the crank sensor. My car now has no cel's on.
charlieboyhonda
Dec 3, 2007 10:06 PM
SirRevvs
11
Jul 15, 2007 03:48 PM
Jose-aka-Pedro
May 21, 2006 06:41 PM
Ls1 FD3s
May 18, 2004 12:19 PM
RoaringTurtle
18
Aug 5, 2002 01:17 PM
