Stuck in Reverse
Old May 16, 2005 | 06:31 PM
hubjub's Avatar
Default Stuck in Reverse
I tried to back out of my garage today, and i couldn't pop the car into R, i tried double clutching but it still wouldn't.
I tried it with car on and off, still having trouble. I managed to pop it in after a while, but once its in, i need to use force to pop it back out again.
My tranny is a JDM 98 R tranny and all the gears are working fine except for R.
I'm thinking its the clutch because my clutch is gonna go real soon, it squeeks all the time
Old May 16, 2005 | 07:26 PM
KayOs's Avatar
Default Re: Stuck in Reverse (hubjub)
Try shifting into 1st gear first then go into reverse.....
I have the same problem and it gets frustrating at times.. ...
Old May 16, 2005 | 07:31 PM
Dan GSR's Avatar
def not the clutch
if it were, it would do it in every gear
my guess, is the 5/r syncro
Old May 16, 2005 | 07:48 PM
OUTKAST_R's Avatar
could be the slave cylinder, had the same thing happen to me on my car, or the fluid is dirty
Old May 16, 2005 | 08:02 PM
nightrider's Avatar
a lot of cars have this over time. 1st, then reverse or 2nd, then reverse does the trick. it possibly also be a going 5/r syncro as someone advised above.
Old May 16, 2005 | 08:11 PM
Dan GSR's Avatar
Default Re: Stuck in Reverse (nightrider)
true
but not being able to get out of reverse tells me its a syncro problem
Old May 16, 2005 | 08:22 PM
Kenso's Avatar
HT White Ops
Default Re: Stuck in Reverse (Dan GSR)
I would also suspect an issue with the 5-R synchro/shift fork.
Old May 17, 2005 | 03:49 AM
Dave-ROR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">true
but not being able to get out of reverse tells me its a syncro problem</TD></TR></TABLE>
Or a shift fork. A friends 99 GS-R had the same problem and it was a bent shift fork.
Old May 17, 2005 | 05:05 AM
98cwitr's Avatar
Default Re: Stuck in Reverse (Dave-ROR)
my R would do it after I had been getting on it. Only happened with reverse too...is it still happening or has it gone away (for now). If its still happening id say its the shift fork...if not, the slave cyl.
Old May 18, 2005 | 06:00 AM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: Stuck in Reverse (98cwitr)
I had that exact problem a few years ago. Wound up needing a tranny rebuild Bent shift forks, fried synchros, bearings done...I was not a happy camper (had just bought the car).
gsr_b20b
Jul 17, 2009 03:53 AM
HavokB18
Jul 26, 2003 05:32 PM
B18cteg
Jul 3, 2003 10:18 AM
tilt
Oct 7, 2002 01:22 PM
