OEM Gas Tank/ Fuel Cell
Old May 16, 2005 | 12:44 PM
LSEGHATCH's Avatar
Default OEM Gas Tank/ Fuel Cell
I will be running a 8-12 gallon fuel cell in my eg hatch and was wondering if I should leave the oem gas tank in place for aerodynamic reasons? If I do remove it, what extent of modification will need to take place to allow less drag?
EDIT: Any/all pics would help
Old May 19, 2005 | 01:36 PM
LSEGHATCH's Avatar
Default Re: OEM Gas Tank/ Fuel Cell (LSEGHATCH)
Bump
Old May 19, 2005 | 01:56 PM
sadangryboi's Avatar
your stock fuel tank is already 8-10 why would u run a same size tank....
and if u want to make it aero dynamic if u take it out...chop the whole rear out like the dragsters and lay some sheet metal over
Old May 19, 2005 | 03:32 PM
LSEGHATCH's Avatar
Default Re: (sadangryboi)
I've seen what needs to be done in order to sump an oem tank properly and the amount of work seems like too much when you can buy a fuel cell. I don't know now though because tracks have to have a firewall between the cell and yourself so........I don't know what I'm going to do. I guess I could use a small cell that'll fit in the engine bay but if I drive a long distance I don't feel like filling up every 1hr or so lol.
Old May 20, 2005 | 04:04 PM
T4eg's Avatar
Default Re: (LSEGHATCH)
Id sump the stock tank. Just measure and drill 5 holes. and weld the sump up. (make sure its air'd out.).
miamirice
16
Aug 26, 2014 05:09 AM
JDM97R
Sep 26, 2009 06:54 PM
hybrid2007
Welding / Fabrication
12
Feb 19, 2009 03:13 PM
blaze_125
Sep 5, 2007 06:47 AM
SPOOLINmatt
Aug 9, 2006 04:59 AM
