just finished my swap but need help on SOme BUGS
Old May 15, 2005 | 09:52 PM
Eg6xCiViCxSi's Avatar
Default just finished my swap but need help on SOme BUGS
ok well i jus finished my swap for my 95 civic si and i put in a jdm b16 sir2 in it and now it just idles funny like it keeps bouncing from 1 all the way to 4 and back down to 1 is there anyway to make it idle normaly im also running a chipped p28 other then that the motor is stock any help would be appriciated
Old May 15, 2005 | 10:08 PM
Default Re: just finished my swap but need help on SOme BUGS (Eg6xCiViCxSi)
any one??
Old May 15, 2005 | 10:23 PM
DaveSi677's Avatar
not sure but it could be an air bubble in the anti-freeze correct me if I am wrong!!!!!!!
Dave
Old May 16, 2005 | 08:34 AM
JDMallTHEway's Avatar
there quite a few things that can cause stuff like that....
Check for:
Vacuum leaks
Wiring problems
as these are very common.
i'm not sure what else to tell you, there are jsut too many variables.
Old May 16, 2005 | 12:55 PM
Default Re: just finished my swap but need help on SOme BUGS (JDMallTHEway)
ive checked the wiring and that wasent the problem we tested all of them and they had power goin to them but im thinkin it is a vaccum leak because when i put my hand on the throttle body the car doesnt die what can cause that? vaccum leak probaly?
Old May 16, 2005 | 02:29 PM
neutron91's Avatar
is the cel on
Old May 16, 2005 | 02:49 PM
JDMlyfestyle's Avatar
where did you get the Chipped ECU from? My bet is some bad programming.
Old May 16, 2005 | 02:51 PM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eg6xCiViCxSi &raquo;</TD></TR><TR><TD CLASS="quote">ive checked the wiring and that wasent the problem we tested all of them and they had power goin to them but im thinkin it is a vaccum leak because when i put my hand on the throttle body the car doesnt die what can cause that? vaccum leak probaly?</TD></TR></TABLE>
vacuum leak for sure.
a bad AICV will cause this as well.
Old May 16, 2005 | 02:53 PM
EG_intheworks's Avatar
Default Re: just finished my swap but need help on SOme BUGS (Relic1)
Im going with bad Vacuum somewhere, check all your lines off the intake manifold and such, I had a similar problem on my prelude.
Old May 16, 2005 | 02:54 PM
Is there any CEL's? if not im stickin with bad programing. I know several people who bought bogus chipped ECU's and they have the wrong maps, and Raised the IAC duty cycle to 100% so that its runnin all the time.
Old May 16, 2005 | 04:52 PM
neutron91's Avatar
Default Re: (JDMlyfestyle)
the sir2 intake manifold doesnt have a map on it if im correct... and hes not running the p30... and a p28 calls for a map... if he doesnt have an external map could that be the prob?
Modified by neutron91 at 8:03 PM 5/16/2005
Old May 16, 2005 | 04:54 PM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">
a bad AICV will cause this as well.</TD></TR></TABLE>
probably not a vacuum leak....vacuum leak would hold constant high idle
IACV is mostlikely the problem or air in water lines
chad's Avatar
Moderator
Default Re: (neutron91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neutron91 &raquo;</TD></TR><TR><TD CLASS="quote">the sir2 intake manifold doesnt have a map on it if im correct... and hes not running the p30... and a p28 calls for a map... if he doesnt have an external map could that be a prob?</TD></TR></TABLE>
if there is no MAP hooked up then this is a problem that needs to be fixxed
Old May 16, 2005 | 08:53 PM
the chipped ecu was in my friends car and his ran just fine we checked that part and its not the ecu im jux thinking its a vaccum leak somewhere i will go out tommorow and check all of the houses 1 more time shouldnt my car die if i cover my throttle body? cuz it doesnt and my friends say it should
fastblacks2k
11
Jan 25, 2010 12:22 PM
NSfit
May 3, 2007 04:28 PM
Dr_Suess
Oct 21, 2005 10:19 PM
wcknockoutk86
Jul 7, 2005 07:21 PM
PDXHatchback
Feb 10, 2004 10:16 AM
