side mount enough cooling for t3/t4?
Old May 15, 2005 | 02:53 PM
wrXtian's Avatar
Default side mount enough cooling for t3/t4?
as the topic states.. i was thinking of getting a decent side mount intercooler instead of the huge front mount just so i don't have to cut my bumper support or front bumper.
thanks
Old May 15, 2005 | 02:58 PM
project dc2's Avatar
Default Re: side mount enough cooling for t3/t4? (D16A6_HF)
IMO bigger turbo = less heat than small turbo
Old May 15, 2005 | 03:50 PM
wrXtian's Avatar
Default Re: side mount enough cooling for t3/t4? (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">IMO bigger turbo = less heat than small turbo </TD></TR></TABLE>
is what i'm hearing a bigger turbo is going to put out less heat in your charge pipes than a smaller turbo???
Old May 15, 2005 | 05:40 PM
urbansi's Avatar
true, but it largely depends on the boost level. bigger turbo will run cooler at the same psi level as the small one, but it all has to due with efficency. get it
Old May 15, 2005 | 05:50 PM
nfn15037's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16A6_HF &raquo;</TD></TR><TR><TD CLASS="quote">as the topic states.. i was thinking of getting a decent side mount intercooler instead of the huge front mount just so i don't have to cut my bumper support or front bumper.
thanks</TD></TR></TABLE>
Why not get a more reasonable sized FMIC rather than a huge one?
Old May 15, 2005 | 05:53 PM
urbansi's Avatar
Default Re: side mount enough cooling for t3/t4? (nfn15037)
well i think the whole reason he wants to get a side mount is so he doesnt have to cut his bumper up, but the piping on my car was really the reason i had to cut things up. really if you get really good fitting pipes, the cutting is very minimal, front mount/side mount there is still going to be some cutting. so either way your going to have to chop a little here and there. and plus you can get a johnny race car intercooler for cheap too, so go which ever way you want but there will still be some chopping sorry to tell ya
Old May 15, 2005 | 06:58 PM
nfn15037's Avatar
Default Re: side mount enough cooling for t3/t4? (urbansi)
I cut nothing on my bumper with a relatively large intercooler, maybe on Civics it is different?
Old May 15, 2005 | 07:05 PM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi &raquo;</TD></TR><TR><TD CLASS="quote">
Not totally true. Until the efficiency range is reached the large turbo will produce hot air as well. It kinda works like and upside down bell curve in terms of output temp vs. PSI. That's the best way I can put it.
Back on topic though A sidemount will work for certain power goals. I'm not sure what they are, but my best guess is under 250whp.....I'm sre someone knows. Many people have used them and seem to work fine. Don't be scared to cut away at your bumper, you will do minimal cutting at best
Old May 15, 2005 | 09:11 PM
wrXtian's Avatar
Default Re: side mount enough cooling for t3/t4? (adseguy)
yeah i don't really plan on boosting more than 8 psi.
Old May 16, 2005 | 05:32 AM
Boosted Power's Avatar
SMIC...will work and hold fine. A t3/t4 at 8psi isn't doing too much just yet.
DSM SMIC can hold 17psi all day.
Old May 16, 2005 | 09:36 AM
adseguy's Avatar
Default Re: (Boosted Power)
I was wondering what is the effective CFM it can cool
WOO HOO 1000 posts!
CustomX113
Nov 20, 2006 09:27 AM
HNLV
Oct 9, 2006 04:24 PM
only1crx
Apr 15, 2005 08:52 AM
AsianMullet
Oct 25, 2003 11:56 AM
boostin b16
Apr 17, 2003 02:31 PM
